'05 TL 5AT: Whining Noise and Burning Smell
Uses turn signals in my
My brother has an 05 TL 5AT: on Sunday the car started with a nasty whining sound followed by a smell of something burning. We turned off the car as soon as I smelled something burning. I looked into the engine bay and did not see any signs of anything foul.
Car has 73k miles on it, all service (including timing belt) has been done on a regular basis. The car has no visible leaks or dribbles. The serpentine belt is new, as is the tensioner assembly and I do not see the belt rubbing on anything.
I recorded a video of the sound (sorry for the vertical video):
https://www.dropbox.com/s/mvh1rcpi2x...615_103553.mp4
Any thoughts on what it could be?
TCM 01 CL-S (06-17-2014)
How did you end up diagnosing it?
I ended up sticking my nose right up on the altenator and i could definitly tell thats where the smell was coming from. I also noticed my navi screen was acting a little strange. There were waves running through it, it's a little hard to explain. I also noticed engine noise coming through the door speakers. My volts were also reading low with the a/c on, heated seats, radio playing (minus the suboofers), headlights on etc. I was getting a 11 volt read which shouldn't happen. I'd check your volt reading with everything you have electrical turned on to see if the altenator is putting out the correct voltage with a load on it
Thanks!
Update: a mechanically/technically inclined relative was visiting the house while I am at work, he believes that it is the alternator. I will replace it and report back.
Thanks the_tl_man09
Thanks the_tl_man09
It's the belt that's burning. Whine is probably power steering. Start at the power steering pump. Whine could be air getting in from the inlet hose. It doesn't appear to be leaking which is good. Make sure PSF is in good condition and between min and max line of the reservoir. With car running, check PSF for micro bubbles foaming at top, turn wheels side to side to note if the whine changes amplitude. If no bubbles or variation in amplitude when turning wheel, check alternator.
Turn car off and look for any belt shavings around alternator housing, then try rocking the pulley back and forth checking for any play. Then check current to battery, if current load is good, pulley doesn't have any play and no belt shavings, check compressor housing for A/C. Turn car on and engage a/c, check for any squeal. A/C should be cold. You can also check for play in the compressor pulley bearing. If that seems all good.. last culprit could be drivebelt auto tensioner. Check the tensioner marks and verify they are in spec, turn car on and check tensioner mark, if it moved significantly, it's ready to be replaced.
You can also remove the drivebelt for sanity check to make sure it's related. If you remove the drivebelt, it will also be easier to rock the pulleys and will allow you to spin the auto tensioner pulley to rule that out as well.
Update: Replaced alternator which fixed the whining sound and also eliminated the burning smell.
After letting the car run for a bit, heard a new sound develop, coming from PS pump . Going to trouble shoot that next. PS fluid level was good, but the fluid is old as hell and there were micro bubbles. I guess I'll tackle that tomorrow.
Thanks for your help the_tl_man09 and Majofo
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
