05+ Driveline Vibration?
05 WDP/Ebony/5AT/NaviLess
Okay, so I've read all the existing threads regarding the driveline vibration and potential fixes etc. There was a TSB released that added a damper and was supposed to reduce the vibrations however it was only for the 2004 TL.
I've been to several dealers and all have told me that the vibration/drone I am feeling is normal. They have also told me that all 2005 TLs have the damper TSB already applied. Here are the symptoms of the driveline vibration I have :
1) Occurs at 1500rpm but particularly noticeable around 80-90km/h (50mph)
2) Has a vibration and a droning noise through the steering, seat and floor
3) Seems to be really bad when cold, but still occurs when the car is warm (not as bad)
4) Switching to a lower gear (i.e. 5th to 4th) makes it go away
5) Only happens on 5ATs
6) The vibration can be quite rough and pretty much vibrates most of the car
7) Has nothing to do with tires or alignment
So now, here is the million dollar question -- who has a 05-07 TL that has this vibration? If you do have it, are the symptoms the same as what I described or are they any different? Have you taken it to the dealer and what have they said? Have you had any fixes or dealer solutions applied and what have been the results?
I have been really frustrated with this vibration and I really want to get it fixed but I want to gather as much information as possible so that I can take it to the dealer and hopefully get them to take some sort of action.
So if you have an 05+ TL please post and help me figure this out!
Thanks!
Thanks!
Originally Posted by JDM5lugHatch
My '05 had it but it wasn't as bad as some have talked about on the boards.
Now with i-Vtec
Originally Posted by pvansh
Mind telling me how? What seemed to fix it?
Sorry was busy at work when I posted. I meant to say that I got rid of the car. That fixed it right up along with all the other issues. lol
Now with i-Vtec
Haha no prob! I'm starting to contemplate the same thing. What car did you move on to?
I went to an RSX-S because I wanted a car that was more fun to drive and easy to heavily mod with a shit load of jdm parts. Plus I missed driving a manual so much.
i have it on my 06 exactly as you described but it was more noticeable when we first got the car and after 2 months it seem to have died down? i guess i'll report back cause i havn't been paying attention or maybe i juts got use to it. But given how yours is an 05, it's probably not going to go away like mine did.
07 TL-Navi 5AT, NBP
Mine seems to do it (07, Jan 7) right out of the dealer's lot. I had the opportunity to drive a co-workers 04 auto home shortly after picking up mine one night while they borrowed my truck. His did the same thing so I guess it's normal. It's not that bad, I thing it's mainly (for me) in the pedal and maybe the wheel. Doesn't seem to transmit to the body of the car. I notice it exactly at 2000 rpm (not 1500 as described earlier). I haven't played around with manual shifting yet (wanting to break the engine in a little more plus it's winter salt-fest here so not much ambition to play). What I do notice is when I feel it it's always around 2000 rpm, different gears.
I believe my neighbor's 04 does something similar as he described it as somewhat of a growl-feeling.. he liked it, feel the power, a tiger in your tank.
I'm getting used to it but distubing as my '94 626-v6 w>200k miles never vibrated the passenger cabin or pedals like that. Maybe because the TL is so quiet and smooth it's more noticeable.
OMGWTF4THGENTL
I just installed a Comptech cat-back on my 6MT. While I was under there I found an exhaust mount that failed, and the mount flange is now making direct contact with the frame. It hink this could be a source of vibration that's I've been feeling.
Have you crawled under and check your exhaust mounts?
OMGWTF4THGENTL
Nope I haven't but I also wouldn't really know where or what to look for. If you get your mount fixed, can you report back? If that fixes the problem I can get the dealer to look at it.
Do this. Jack up and support one side of your car. Crawl under it and grab the exhaust system (when cool of course), at the center resonator. Shake the shit out of it and look for hard contact points (where rattling might be occuring).
You're never going to diagnose this problem by posting on Acurazine.
Registered P.I.M.P
I have a feeling this is normal. I get this vibration too around the 80kmh speeds when its just cruising at 1500rpm. I think its normal. Doesn't bother me too much really but I do notice considering I just got my 05 TL.
I don't think its a mount as the vibration is much more than something loose. I've had many loose things on my previous car and all they did was make a lot of noise.. hah
I don't think there is a fix.. by the sounds of it, this is normal.
Originally Posted by SSMTL04
Search in the Service Bulletin thread at the top of this section. There is a TSB for this vibration. Just bring it to the dealer and show them.
Nobody has this vibration??
I just started getting the same problem, but I figured it was the suspension. It basically is vibrating my whole car and it is getting annoying.
I have a 07 TL and seem to have the exact vibration you guys describe. I have only 900 miles on the car and I am afraid to even think that I will have to bear with this vibration for a long time until I get rid of the car. My 97 accord had it...got a 99 Accord and the car was smooth as silk (except for the transmission failure and I had to pay 1/2 of the cost to get a rebuilt). An unhappy customer, I am cursing myself for buying another Honda product.
Driveline vibration on '06 TL 6MT
It is funny : the dealership thought I was imagining things....but I have brought the car in 3 times since I bought it, the first time they re-did the alignment, the second time rotated and road forced the tires. When I brought the car in for the 3rdtime , I asked the service director to test drive my new TL to experience the vibrations felt through the floor, steering column and really everywhere in the car. He acknowledged the issue and after another day in the shop, triumphantly called me to say that he thought he fixed the vibration problem. He mentioned that he had replaced all 4 (already new) tires. I took the car for a drive. It was better, but still does not feel right.
I pretty much experience all your symptoms. I would agree, it seems to come from the engine or driveline, I am not a mechanic but this is really annoying for a car which costs $30k +
I am a little tired of going back and forth with the dealership and am curious to know if you have ever fixed your issue by now....
I think all of us who have the 1500-2000 RPM vibration should call Acura client service and bitch about it until they listen and find a fix for us. We paid for supposedly a reliable and trouble free car and we shouldn't accept anything less for the money we paid.
i have this vibration even when in PARKING
even when the car in neutral or P ...rev the engine to 1500-2000 RPM ...i can feel the vibration and growl...this can also be heard when turn on the car...from outside of the car of course...cause as it crank up it jump around 1500 RPM for a few seconds...here is my theory though...there is a TSB for LONG CRANk AND HARD START that replace the FUEL INJECTORs and this might help because on my mom maxima which has bad fuel injectors...have the same/worse shaking vibration feel to it...not related to engine mounts or anything
Aside from the 1500 - 2000 RPM vibration and drone, my car also vibrates terribly when the RPM is between 1000-1100 while in Neutral or P. While idling, if I press the gas paddle until it hits 1000-1100 RPM range, I can feel the vibration as if the car is missing. This vibration literally shakes the whole car kind of like one of the piston is misfiring. The dealer told me that it is normal for TL. Any of you are experiencing this also?
Thanks.
Thanks.
I second that this issue appears on 06 TL 6spd.
I turned down a brand new TL that had road noise (only when moving). The car had a weird drone at low RPMs in 5th and 6th gear, and started at about 50 mph and could be felt all the way until about 85 mph.
Luckily for me, I always do a good test drive before buying. The dealer started feeding me crap about car sitting on the lot for too long, tires need rebalancing, rotors resurfacing, alignment redone, etc and I said let me test drive another one to compare. I stayed away from that car and demanded that the dealer let me test drive another car or will loose my business. In 30 mins he rolled out exact same color combo, I test drove it, and it was perfect.- the one I'm driving now.
I have an 05 automatic with the same vibration issue. If I am trying to maintain a speed of 50 mph by lightly touching the throttle, I get a bad vibration in the peddle and steering wheel. If I push the throttle further down or let off, the vibration goes away. I am taking my car in for service on Friday but now have even less confidence that it will get fixed after reading the posts in this thread. To be honest, I am pretty disappointed with my TL and the service department for my local Acura dealer. This will be the third time I have taken my car in with a complaint about rattles (first time not reproduced by the service dept. second time they told me my tires were causing so much vibration they couldn't locate the source of the rattle). I had the cruddy Bridgestones so I replaced with some Yokohamas but I still have the rattles. I also have the faded dashboard syndome around the passenger airbag. I just didn't expect these kind of problems with a near-luxury vehicle, and if I did have these problems I would expect them to get fixed. I am keeping my fingers crossed that the rattles and vibration are taken care of this trip. Sorry about the downer post, but I REALLY want to like this car. However, my wife's G35x is looking like a better purchase as the days go by.
I'm having the tranny replaced just before my 5 year major parts warranty runs out on my 2004 TL. The droning/vibration happens at around 35 to 40 mph, under 1500 rpm. The noise sounds like the car is rolling over lane markers on the highway. I had the Acura technician test drive it. Probably only getting a remanufactured tranny though. At least I don't have to pay for it.
I got my 05 TL like 2 weeks ago and i feel the same thing u guys are feeling around 45 to 50 mph.I'm a tech for honda and i dont think it feels right, so i took it to the acura side and the tech told me that he did not feel anything. At the end of the test drive he said if u want the tranny replace i'll do it but every thing look and feels good on the car. now im thinking about it it might just be that all 05 TL have the same problems.
