05 automatic tl transmission oil change
pretty easy
drive car to warm up fluid
park car on ramps or jack up
remove drain bolt on trans
let fluid drain out
replace bolt
add just under 3 qts of fluid
lower car and test drive checking for leaks and you're good
if you want to do the 3X3 do the above but add drive 5 miles at the end between the 1 and 2 change and the 2 and 3 change.
let fluid drain out
replace bolt
mada51589
05-03-2022 08:54 PM
Zonian22
11-14-2015 01:20 PM
mugen_kid
11-13-2015 10:38 PM
