'05 Acura TL 148k
'05 Acura TL 148k
Hey guys, i have owned my TL 3rd generation for about two years now. I've had some bad luck lately with a lot of things and it now includes my vehicle. About 30 days ago i had the battery die on me which ended up being the Alternator completely dying. I changed the part and once i did i started feeling the dashboard shake a little once i turned on the A/C. A couple of weeks later my Crankshaft Pulley decided to break with the Houston weather that we have been getting lately. Luckily i had a professional who is a friend of my brother in law who changed it all out for only $230. I am now a little worried about the shaking in the car. It has a new belt, Alternator and crankshaft pulley but it would shake (very noticeable) whenever i would turn on the A/C. Once i start moving i won't feel it anymore but once i stop at a light i would feel the vibration. Has any of you guys had this problem lately and know of a solution? Any help or troubleshooting would be appreciated.
-David
-David
-David
-David
NBP04TL4ME (06-22-2015)
Thanks for the advice. I did turn on the car and put it on Neutral and noticed a small change in the vibration. I doubt my transmission mount is gone but i do think that the rear mount is the part causing the problem. I might just be a little skeptical due to the bad stuff that has happened because the vibration seems to go away or it is very noticeable. I just like to take care of my car.
Open up the engine bay and look at the movement of the motor. Does it rock forwards and backwards more than 1/4 inch? If yes, mounts are most def. the cause and need to be replaced.
Zonian22
11-14-2015 02:20 PM
BlkTxAcuraTypeS
10-18-2015 09:05 PM
sockr1
10-01-2015 02:31 AM
asahrts
09-04-2015 06:55 PM
