04 transmission failing until turn engine off
Old Oct 16, 2019 | 09:45 PM
05bce's Avatar
3rd Gear
my tl transmission died or failed on a trip.
I had to pull over then I thought i would restart ad see if i could limp into a town
found out i could go as hard as i wanted if i shut the engine off for 30 seconds
but that would only last 2 minutes then turn off again
help!!
Old Oct 23, 2019 | 12:38 PM
get a new transmission?
Old Oct 23, 2019 | 06:42 PM
Jackass's Avatar
Check fluid condition. Any other symptoms, lights, etc? What is it doing at the 2 minute mark? Smoking? Spewing fluid? Flashing D?
Old Oct 23, 2019 | 07:50 PM
05bce's Avatar
3rd Gear
i will check to make sure but what i do know it fades out kind of slowly
also i didn't see flashing d but i will look
Old Oct 26, 2019 | 02:42 PM
05bce's Avatar
3rd Gear
i test drove it today id doesn't loose tranny fluid it seams reddish still no special lights like flashing d
it is solid til it starts its drop out cycle and then it goes to 0 motion
if i start it with out going anywhere and let it idle for couple minutes when already warmed up it has 0 motion when i put it in gear
if i start it cold and leave it idle for 5-10 min then put it in gear then i have 0 motion
shut it off for a min it will go
oostevey
Eastern Canada
175
Mar 19, 2014 12:01 AM
nisif
Jan 27, 2012 11:33 PM
rob_acuraoflynnwood
Nov 8, 2011 06:13 PM
The Skeptic
Mar 26, 2009 08:02 PM
