04 TL w/ Rear Brake Drag - BOTH rear Calipers sticking? Please HELP me!!- Thanks
B A N N E D
hello, i have this problem concerning my new brake discs and pads i just installed a few days ago. i changed the front and rear at the same time. both of the rear brakes make this constant grinding sound alomst like a "whisk whisk whisk" that gradually increases with my rate of speed. and at freeway speeds it sounds like a constant "phffhffffffffphphphphhhpfff" im assuming its what they call when a caliper sticks or brakes "drag". when i hit the brakes, it either stays the same (amount of noise) or gets even louder. it will not go away. i dont understand, because ive changed the brakes in the front and rears of many hondas before and never had this issue. its so embarrassing that i stayed at home all day Sat. Sunday, and even Memorial Day( today) because of the incredible amount of embarrassment i feel when people WALKING are breaking their necks doing double takes like- WHA?? that was THAT car making that sound? or when im getting paced in traffic by a piece-o-shi* car i just passed by because they just wanted to catch up to me to confirm that it wasn't their car making that sound and it was really just mine. YAY that one is my favorite. that one is the BEST! how does one go about fixing this problem? that is my main question, without buying new -EVERYTHING for replacement. unless it is absolutely required. i drive a 2004 TL 6 spd MT. but its only the rear brakes doing this- BOTH sides on the rear. i took the caliper pins out and cleaned them, regreased them, checked the pin boots. what else have i forgotten? i thank in advance for anyone who is so kind enough to share their good knowledge with me so that i may finally leave my house, lol. but seriously though.
The caliper piston could be sticking, preventing them from moving freely out and back in as you aplly and release the brakes.
The sound you describe sounds like your rear rotors are not flat (a little warpage). If you turn your wheels by hand, is it very hard to turn?
Also, check the handbrake to be sure that it is not stuck. (Remove the brake calipers in the rear and try to turn the rotors by hand, any sound of friction?
B A N N E D
Another thing to look for is the brake pad guides. Do the pad slides freely in them or do they bind?
There is usually rust that will form in the guides and they need to be cleaned out and lubricated.
Wish I was in the neighbourhood, it is alot more easier to solve a problem hands on then at a distance.
B A N N E D
With caliper piston seizure, you would have felt it when you tried to move them by hand.
It can feel like it's not moving smoothly or you feel more resistance or when they are seized, you need a C-Clamp and even then it might not even bulge.
Here is your next assignment; Get the help of a friend!
Put the rear end of the car on jack stands, remove both rear wheels. and leave the brakes caliper installed.
With a light, flashlight etc, look at the piston while you firend would press on the brake pedal on and off, you should notice a small retraction of the piston as he release the brake pedal.
If you do notice a retraction, it's the brake guides or caliper pins that binds.
See the following thread, they have picture of the service manual, check page 19-27 in the first message of the thread.
Best of luck to you
Best of luck to you
B A N N E D
hey i really appreciate your efforts to help me and taking your time to do so. but i am proud to say its a beautiful day today!! Problem has been solved! i am a stubborn idiot for not realizing this prior to all my blind problem solving techniques, its just that at first i wasnt willing to accept the possibility that my new pricey aftermarket rotors in the rear were possibly the culprit but after spending more than the cost of the rotors over the last few days in all kinds of misc costs from tools to parts, its now easier to consider the possiblitity of the rotors . so last night at 3 in the morning ( my neighbors have got to hate me, lol) i replaced my rear rotors with the worn stock ones and bingo, what a sigh of relief to have worn brake rotors back on, isnt that funny. so my lesson i learned is that oem is oem for a reason and i will never punish my check book like this again. hehe. thanks again. take care!
nuldabz
09-03-2015 05:49 PM
