'04 TL A-Spec Acelleration Vibration Issue
Old Sep 20, 2011 | 01:36 PM
blkrb21's Avatar
I have a 2004 TL A-Spec and in the past few months I have had vibrations in the steering, floorboards, and seats between the speeds of 60-70 mph. There is no vibration above or below these levels. I have had the tires rotated and balanced and am still having the same issue. I also had the rims checked to see if there were any bends and there was nothing there either. HELP!!
Old Sep 21, 2011 | 01:41 AM
ohsixMTee's Avatar
Early Shifter
FWIW axles can cause acceleration vibrations, might not hurt to inspect the boots on yours. Possibly one is torn, spat out grease and is now dry/failing?
Good luck.
Old Sep 26, 2011 | 11:53 AM
bigg_86's Avatar
I have the same problem, 04 TL 6spd, I just bought new wheels n tires, had the car aligned, checked wheel bearings, tie rods, ball joints, and everything is in place n no play at all. I even replaced the drivers side axle bcuz that's where the vibration comes from n it didn't help....
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
Frathora
Sep 28, 2015 11:29 PM
kuzdu
Sep 10, 2015 08:42 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
