04 TL Popping Noise & Pedal Vibration
Old Feb 28, 2008 | 09:58 PM
NBPacuraTL's Avatar
Herro
Hello, been lurking around here but never got the guts to post lol. Anyways
As another problem forum member Indy has, i have a problem with hearing a popping noise coming from the driver front side when steering while accelerating slowly from a stop and accelerating then coasting and accelerating again.
Then sometime afterwards, I was taking a turn and applied the brakes (not hard, but not soft) and I heard some sort of deep clicking like something was rotating and hitting up against the brake pedal (I could feel it through the pedal of course)
My question is what could be the problem and if they are somewhat connected.
Thank you
Old Mar 1, 2008 | 01:26 PM
NBPacuraTL's Avatar
Herro
bump for comments. still having the problem
Old Mar 1, 2008 | 01:42 PM
01tl4tl's Avatar
if you turn the wheel from a stop and slowly go- if you get click click click
thats often CV joint
If not a DIY person- have it checked at a shop immediatly
Cure is to replace the axle assembly
Old Mar 1, 2008 | 01:46 PM
NBPacuraTL's Avatar
Herro
ok thanks. any comment about my brake pedal vibration? i guess it's kinda like a grinding noise if it helps more.
Old Mar 1, 2008 | 02:44 PM
TylerT's Avatar
Turd Polisher
I have the same exact problem, only with the gas petal at highway speeds and the initial 900RPM mark.
Old Mar 7, 2008 | 07:11 PM
NBPacuraTL's Avatar
Herro
last bump for solutions
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
