'04 TL Auto Squeeking at 132,000 miles...
Acura OG
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
So I just started hearing a squeek/creeky noise coming from the front of the car while accelerating from a stop. It happens while braking also. I only hear it at ~5 mph which. It seems to happen when there's a load on the engine leading me to believe that it's a motor mount but I just had one replaced (50830-sep-a02) There are three total, right? Maybe one or both of the others is shot now? It's confusing though because why would a motor mount squeek while braking at ~5mph?? I've also thought that it may be a suspension bushing of some sort. Has anyone else here experienced this? Any help is greatly appreciated!
Thanks,
Anthony
Thanks,
Anthony
If it a squeal at low speeds it may be your breaks. You should have replaced all of your engine mounts and tranny mounts at the same time. When one goes bad the rest are soon to follow. Do more tests with the windows down so you can really tell when it happens the most. Suspension as you said could also be the source.
To eliminate brakes and the rest of the drive train, hit the gas with the brakes on so the car won't move. If it does not squeak anymore, I would skip the mounts and start with brakes/suspension.
Also, this takes another person, but pop your hood, have someone step on the break and lightly power break it while you check out the engine. you will see it lifting if your mounts are bad.
Acura OG
Looks like this may be the solution:
https://acurazine.com/forums/showthr...ghlight=squeek
I'll have it done and report back.
Pham Alvan
03-16-2016 09:17 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
