04 acura TL lights all on
04 TL, bought car vsa,abs,!, lights all on. went through brakes, replaced rotors,pads and found bad caliper in rear so replaced. lights didnt go off so i figured wheel sensor was bad on same wheel as caliper. replaced. While down i replaced timing belt, water pump tensioner yada yada. start car and check engine light added to the mix. i hooked up my code reader it says cam sensor int failure. Tore back apart and replaced it. light come back on now says crank sensor int failure. replaced and light came back on same code.took to honda dealer they said crank sensor int failure. want to install genuine honda sensor,check wires etc for $849. i took it home checked wires my self. have found nothing that fixes it. seems to run fine just dash looks like a xmas tree. Had bad battery when i bought it. installed new interstate. this was two months ago nothing changed. any thoughts?
shtewps
03-05-2021 09:49 AM
