S is for...
Old Feb 12, 2009 | 02:14 PM
  #41
sT04Louis's Avatar
Nikon Neck Beard Krew
Originally Posted by 07typeSjdm
tl is looking proper.
clean and simple
Originally Posted by HONgDA
You have before and after shots to compare? BTW, what brake pads did you get that doesn't squeal?
Got the Rotora Street Pads, They are Silver in color...but forget part number.
Here is the best pic i can find that shows how they were before...its kinda shows the difference, especially rears.
Originally Posted by Distorted Reality
Sick bro.
Old Feb 12, 2009 | 02:21 PM
  #42
HONgDA's Avatar
2005 TL (7/07-8/29/09)
http://farm4.static.flickr.com/3007/...691c80.jpg?v=0
Did you get them from Excelerate? I wonder if they fit the StopTech BBK.
Old Feb 12, 2009 | 02:29 PM
  #43
sT04Louis's Avatar
I was looking into a pad from a diff company, and if you email Rotora they will send you the schematic for the pads so you can know exact size.
And yes i got them from Excelerate.
Edit: Just thought about this too, how are your pads held in? On the Rotora kit there are two pins that go through the caliper that hold the pads in. Not sure if it is the same on StopTech.
Old Feb 12, 2009 | 03:12 PM
  #44
04 tl's Avatar
that shit looks crazy bro!!!!
Old Feb 12, 2009 | 04:33 PM
  #45
HONgDA's Avatar
there is a bolt-in bridge as they call it and retaining clip that goes over the pads and is held on with those two allen bolts.
Old Feb 12, 2009 | 04:44 PM
  #46
sT04Louis's Avatar
Yea, sounds different...
Here is the Rotora Caliper.
Old Feb 12, 2009 | 05:11 PM
  #47
HONgDA's Avatar
Wow interesting, i thought Rotora had that too. Stoptech ftw! jk
From Stoptech:
STIFFER CALIPERS MEAN BETTER PERFORMANCE AND FEEL
Using finite element analysis (FEA) modeling software, we have designed a bolt-in bridge strong enough to stop distortion without sacrificing cooling through the top of the caliper. Distortion is virtually eliminated. The squeeze forged StopTech ST-40 caliper has the least flex of any tested aftermarket and OE caliper. The air channel in the bridge is designed to help air flow through the retainer, resulting in better cooling.
Old Feb 13, 2009 | 09:45 AM
  #48
sT04Louis's Avatar
Good luck in your search.
Old Feb 14, 2009 | 11:39 PM
  #49
flip_side's Avatar
can you go any lower?
Old Feb 14, 2009 | 11:50 PM
  #50
sT04Louis's Avatar
Sure,
Add more camber and remove fender liners.
Old Feb 15, 2009 | 12:02 AM
  #51
flip_side's Avatar
Do want.
Old Feb 16, 2009 | 11:05 PM
  #52
sT04Louis's Avatar
doooo it
Old Feb 17, 2009 | 06:34 AM
  #53
milk man's Avatar
how is everything with the spacers? like anything you have to watch out for ?
Any rubbing yet?
Old Feb 17, 2009 | 08:07 AM
  #54
Spiritman's Avatar
Man of God.....
Cool
Sadly...my SPC camber kit is maxed out at -.5 camber...i wanted to have -1.5. Maybe ill have to look into a ingalls kit.
Now I am confused! I thought that we were looking -1.0 +- .5? Is this right? What are the preferred spec. for the rear of my 06 6mt. camber?
Old Feb 17, 2009 | 10:35 AM
  #55
sT04Louis's Avatar
Any rubbing yet?
Nothing ive needed to be worried about yet, ill probably look into some hubcentric rings, just need to measure the spacers.
I have rubbed in the back, and on the front bumper where it meets the fender, also top of fender liner but thats not because of spacers.
So ive trimmed away part of the bumper, and just dont throw my car into corners that hard.
That is right if youre looking to be in spec. With the offset im running, adding more camber is "better" looking than having to raise the car back up.
In the rear im running -1.5, im still on the fence about going to -2 in the rear, and i would like -1 or -1.5ish up front to help clear a bit more.
Old Feb 17, 2009 | 10:56 AM
  #56
Spiritman's Avatar
Man of God.....
Cool
So for an 06mt/Aspec The numbers are like I said? -1.0 +-.5 ? I just want to know cuz the place I brought my car didn't have the numbers for the rear. It always comes out back light in red. Cuz he doesn't have the numbers in his machine. Thats why I buggin you so much. So thanks in advance!!
Old Feb 17, 2009 | 12:19 PM
  #57
sT04Louis's Avatar
Yea when i was having my camber put in spec it was -.5 front and -1 rear, so keep it around there and you should be fine. A little more rear wont hurt, just make sure the toe angle is as close to 0 as possible.
Old Feb 17, 2009 | 12:39 PM
  #58
bumski667's Avatar
NBP
so nice...
Old Feb 17, 2009 | 02:55 PM
  #59
milk man's Avatar
what did you trim the front bumper with? bc i have the same problem now
Old Feb 17, 2009 | 03:46 PM
  #60
sT04Louis's Avatar
Originally Posted by bumski667
so nice...
Dremel with a sanding wheel. At very low speed so it wouldnt melt the plastic.
Also trimmed some of the fender down so it wouldnt have a sharp point.
Old Feb 17, 2009 | 05:11 PM
  #61
milk man's Avatar
^thanks bro ...
Old Feb 18, 2009 | 12:24 PM
  #62
sT04Louis's Avatar
no prob.
Old Feb 18, 2009 | 03:27 PM
  #63
milk man's Avatar
^guess what ? i got a 15mm spacer on the way for the rear gonna put it on and see if it works ... so i ll be 18x9+25 245/40
Old Feb 18, 2009 | 03:51 PM
  #64
Littlecowc8's Avatar
Clean!!!
Old Feb 19, 2009 | 02:01 PM
  #65
sT04Louis's Avatar
Nice that should fit pretty good...as long as you are rolled already my rears are at +23, but on a 19x8.5 so ita gonna be close.
What are you gonna use up front??
Originally Posted by Littlecowc8
Clean!!!
Thanks.
Old Feb 19, 2009 | 03:15 PM
  #66
milk man's Avatar
not sure yet ... my tire on the driver side is scraping where the bumper meets the fender just like you .. but maybe for the front ill do 5 mm spacer so it would be +35 i know that's weak sauce but i ll see
mrlemonjello
Sep 1, 2015 08:52 PM
DEPTLS
Sep 21, 2008 01:49 PM
is300eater
Jul 26, 2008 06:08 PM
'01White3.2CL
Jul 18, 2008 12:42 AM
