Pic Request - Base TL or TLS with A-Spec suspension and 17" rims
Hey everyone - Would someone please post pics of a base TL with A-Spec suspension and 17" rims? I'm thinking about upgrading to the suspension but don't want to create a weird wheel gap with my 17" stock wheels. Thanks!
I tried searching and wasn't too successful. I found lots of posts with the body kit, but few with just suspension.
triax37 (08-10-2012)
david_vang (08-10-2012)
You mean if the car would be lower?
If that...
If you get 17"
and these tires
235/45/17
+105.75mm
255/40/17
+102mm
Vertical lenght of the tire will be 17 inch + 102mm + 102mm
17" is 431.8 mm
Total lenght: 635.8
If you get 18"
and these tires
235/40/18
+94
Vertical lenght of the tire will be 18 inch + 94mm + 94mm
18" is 457.2 mm
Total lenght: 645.2
17" giving shorter lenght will make the car sit lower... ifff you use justns tires
which I recommend
Edit: If you have the stock tires which are 235/45/17
Total lenght will be 1.9mm shorter than 18" ones I said up there.. not a noticable difference
If you have justns tires with 17", you'll sit lower and noticable difference... I think
If that...
If you get 17"
and these tires
235/45/17
+105.75mm
255/40/17
+102mm
17" is 431.8 mm
Total lenght: 635.8
If you get 18"
and these tires
235/40/18
+94
18" is 457.2 mm
Total lenght: 645.2
which I recommend
triax37 (08-12-2012)
oyayjoe
09-12-2015 04:40 PM
nuldabz
09-03-2015 05:49 PM
