Hi all,
This is my new Turbo build in progress, first post. I will start adding pics and keep you up to date on progress
Car: 2004 Base TL Manual
Interior:
- Haltech IC7 display with OBD-2 cable
- Gerzy Bear custom steering wheel
- Gerzy Bear carbon fiber bumper
- K-Tuned shifter
- Corbeau Sportline RRS Leather seats
- Carbon fiber trim kit Exterior:
- Mineral white (engine bay to match)
- 2007 Side Mirriors with Turn Signals
- Gerzy bear front bumper
- H.I.C Rear Visor V2
- Complete Artwork Bodyshop kit
o Front splitter -Gerzy Bear
o Rear Diffuser
o Side Splitters
o Rear Spats
- Complete Custom WiseDetailz Light setup
o Rear Tail Lights
RGB Bluetooth Color Changing Function
Red Turn Signal
Ceramic Coated
Lightly Smoke Tinted
o Side Markers (Front, Rear and side mirror)
LED
Smoked
Ceramic Coated
o HeadLights
TLX jewel eye projectors
RGB color changing demon eyes
Smoked/cleared side reflectors
Blacked out housing/internals
Ceramic coated lenses Engine:
MODS
- Honda OEM Parts J35 crank
- IP_J35_rods InlinePro Honda J35 Turbo Connecting Rods set
- Racehead_6 cyl Bore & Hone, block decking
- Racehead_6cyl_1000rpm balance
- IP_J_series_Headstuds InlinePro J-Series Headstuds
- CP89.5_Jseries_pistons CP custom InlinePro Pistons J35 89.5mm, 10:1
- IP_Supertech_valve_JSeries Supertech custom InlinePro J35 Valves
- SPRK-H1003S-J32 Supertech Single valve spring kit, retainers, seat Honda/Acura J35A
- CNC_Cylinder_Support
- Racehead Cylinder head completion valve job
- 12251-RDJ-A01 Honda OEM Parts Acura TL 2003-04 head gasket
- Fluidampr Performance damper
- Gates power steering pressure hose
- Doorman power steering reservoir
- Marshal fuel pressure gauge
- CSF full aluminum radiator
- Skunk2 Magnetic drain plug
- Braided Clutch line
- Hondata 4 Bar Map sensor
- Denso Primary 02 Sensor
- Vibrant Oxygen sensor SS bungs and 02 sensor bung relocation on both up pipe
- Radium Auto Fuel pressure regulator, hose upgrade, Return type fuel system
- AEM Water methanol injector Monitor
- Billet P2r Fuel Rails, Radium Auto Fuel pressure regulator, Return type fuel system conversion
- Innovative Engine Mount Acura TL 2004-08
- Innovative Mount transmission Pair for Acura TL 2004-08 6 speed Manual
- Custom complete cat back 3”
- Vibrant resonator
- Vibrant muffler and tips
- Borg Warner S362 Billet Wheel Turbo
- Turbosmart 45mm Hypergate
- Turbosmart Raceport BOV
- 550HP Intercooler
- Custom Stainless Steel Manifold
- Custom 2.5in Aluminum Charge Types
- Custom 3in Stainless steel downpipe
- Turbo oil feed and oil drain lines
- 255LPH Fuel pump
- 650CC Fuel injectors
**Probably missing a bunch of stuff**
MAINTENANCE (A lot more, just cant remember)
- Turbo inspection (original Turbo had a leak)
- intercooler piping leak test and fix
- Steering rack replacement
- Ball joints replacement
- Vband clamp on front uppipe (too small, bolt is stripped)
- oil return modification on oil pan, oil feed upgrade (hose is cracked)
Bumper fitting and I got the the splitter kit, it looks amazing. I made a mistake on the rear diffuser so it will be sent later and will upload pics when I get it.
Thanks to Artwork Bodyshop (fast and great work, really impressed)
I am getting all my lights done by wisedetailz and he needs some measurements from me but my car is getting painted right now and don't have access to it. Any chance anyone can do 3 measurements for me as we have the same car
the 3 measurements I need are
-Headlight to front side marker
-Front side marker to rear side marker
-Rear side marker to tail light
Aren't you from the Quebec TL group?
I wished you'd avoid Wized. There's A LOT of people who are dissatisfied with his product. And I don't know why he would need measurements when he works with TL parts all the time---he used to be a member in this community until a whole scandal broke out.
But if you absolutely must go with him... just beware of him and the product you may receive.
Is no one gonna talk about....... did you program and mill your own closed deck? Or is it semi-closed, with coolant holes? That's fuking awesome!!
Also I was hesitant about your choice of blue to white, but that picture on the trailer..... HOT DAMN!!
