Made a front plate bracket
'06 WDP TL 6MT
NJ requires a front plate, and putting it in the front window doesn't fly (officially). Ever since I removed the OEM front plate bracket to clean behind it, I've been driving without a front plate. I like the look so much better, and I also ordered black decals to go in the ACURA inset on the bumper. The OEM plate bracket covers that area entirely. ![Frown](https://acurazine.com/forums/images/smilies/frown.gif)
So I set out to mount my plate somewhere else in the front of the car. I saw the RHO-Plate bracket which uses the tow hook location, but I wasn't about to spend that much money, and it puts the plate a bit too high for my taste.
I decided to do it myself. A couple of L brackets, nuts, bolts, and washers, and this is what I came up with. I had to drill 2 holes in the lower air dam, and had to do so without removing it since I would first have to drop the A-Spec lip.
I used rubber well nuts like these to attach the plate to the bracket, which protects the bumper/lip. Now I need to get a set of WDP plugs for the holes in the front, and apply the ACURA decal when it arrives. And this snow could take a hike too. I sure picked a miserable day to work on the car.![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
![](https://acurazine.com/forums/picture.php?albumid=7331&pictureid=38368)
![](https://acurazine.com/forums/picture.php?albumid=7331&pictureid=38369)
Nicely done =)
Bone stock tl-s
Looks good dude, I like it when people think up mods and do it themselves. Very simple design, nice.![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Only thing different I would have done would be is to shape the plate curved to follow the bumper contour for a flush cleaner look. A large pole, a bucket, paint pail whatever to shape it. Just an idea.
B A N N E D
so it will probably need to be reinforced from the rear, but a bit of thicker aluminum flat bar, would more then likely take care of that though (should be available at your local Home Depot lol)
'06 WDP TL 6MT
Haha thanks for all the comments. NJ plates are not completely flat like some other states I've lived in. The letters/numbers are actually raised, and there is a beveled edge around the plate. I don't know how well it will form a curve.
Regarding reinforcement, I stopped back at Lowes tonight and picked up two more well nuts for the top plate holes. The plate is now tight against the bumper/lip with those rubber nuts, and of course bolted to the bracket.
B A N N E D
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
I think it would look better further to the corner instead of so close to the center? Otherwise it's a nice cheap mod you've done. I wanted to do something like this also, but I've just been running no front plates for almost a year now. Only 1 ticket from a meter maid while parked on my block so far. Don't really get much problems thank goodness.
'06 WDP TL 6MT
The further I would put it from the center, the more the plate would be angled "not forward" if you know what I mean. Or I'd have to make one mount stick out much further than the other, so the plate would be square towards the front of the car. That's why I opted to put it there.
I know the plate will bend if I hit it with a mallet, what I mean is I'm not sure if it will take a nice smooth round curvature, since it has a bevel or "bead" around the edge. If you try to bend it, it tends to twist.
Thanks for the comments and ideas though, I appreciate it. I may put a license plate frame on it if I see something nice.
Received 6,470 Likes
Clean and simple-well done.
'06 WDP TL 6MT
I saw your pics the next day after I did mine. I'm going to give it a bit of a bend, and I did put on the dealership frame until I find something nice and understated.
I kinda have a more ghetto way of doing it..
3M double sided tape, around the plate then right on bumper, I didnt want to drill into the bumper, and haven't had time to make one
CARBON FIBER WDP TL
justin7779
12-25-2015 10:33 PM
