Headlight restored
Old Apr 6, 2017 | 11:47 AM
truonghthe's Avatar
Smile Headlight restored
Before
Before
Prep up and ready to go
Before
Before
After 1500 grid sand down.
Finish product
Nice and fresh
So crips....
I can actually see the cut off line.
After 3000 grid sand down
Right side...
so i recently just bought a base TL and notice the headlight need some
luv. I got it sand down from 1500-2500-3000 grid and polished the lense, i use opti coat to finishing up the touch. Lets the pictures For result.
Old Apr 6, 2017 | 12:49 PM
NoTLoud's Avatar
Very nice results!
I got do a quick restore on my headlights because they're torn up from rock chips and have a very slight haze.
Old Apr 6, 2017 | 01:35 PM
Yvuru's Avatar
looks great! i'd recommend a xpel pre-cut clear protection film for those headlights. keep that hard work protected (its what I did to mine and i've had no degradation since)
Old Apr 6, 2017 | 02:13 PM
that Boi T puttin in WORK
Old Apr 6, 2017 | 02:19 PM
truonghthe's Avatar
Trust me no film gona last with Houston summer sun, I had clear coat spray on my lexus and its a PITA to remove (lasted me for 4 years). I went with Opti Coat instead, easy to remove and easier to restore.
Speaking of the boi who offer me for assistance on detailing, where were you at boi?
Old Apr 6, 2017 | 02:21 PM
well the job did lay me off for a month a half......but picked me back up this week.
Old Apr 6, 2017 | 09:47 PM
Steven Bell's Avatar
Old Apr 13, 2017 | 01:00 PM
imj0257's Avatar
Q('.')=O
Looks much better. But yea.. gotta put clearcoat or something on.. won't last in Houston.
Old Apr 22, 2017 | 08:00 PM
PVD24's Avatar
Amazing job... Can someone explain the step by step process. Do I need a sander or can I do it by hand? What products and shopping list do I need?
Thank you in advance.
Old Apr 23, 2017 | 08:33 AM
SuperBrianKlein's Avatar
7th Gear
went with the 3m restoration kit this past week, worked out great
Old Apr 23, 2017 | 06:02 PM
Tlboo2's Avatar
Geez well done.
Old Apr 26, 2017 | 03:48 PM
supertomcat's Avatar
5th Gear
looks great. If you don't mind me asking how long did it take to complete?
Old Apr 26, 2017 | 10:39 PM
truonghthe's Avatar
an hour.
Old Apr 27, 2017 | 09:48 AM
sockr1's Avatar
looks great!! i did the same a few years back and it makes such a huge difference
Old Apr 27, 2017 | 09:32 PM
4cruizn's Avatar
Great job on that!
Old May 11, 2017 | 08:14 AM
f1r3w0rK5's Avatar
Yes, you did a great job!! It does make a huge difference. . .
Old May 14, 2017 | 04:16 PM
She'sCalledDrGrey's Avatar
You inspired me to tackle mine this weekend.
Old May 14, 2017 | 07:37 PM
Ryan L21's Avatar
^^^ What did you use to seal? Clear or just wax or some sort of sealant?
Last edited by Steven Bell; May 15, 2017 at 06:41 PM. Reason: No need to re-quote the previous post, especially if you're the next person posting.
Old May 15, 2017 | 08:38 AM
I used the sylvania kit. It comes with a uv clear coat/sealant.
Old May 15, 2017 | 06:41 PM
Looks good!
Old May 16, 2017 | 01:41 PM
mazen222's Avatar
very nice! mine is due as well!
Old Jun 1, 2017 | 12:40 AM
tpz76's Avatar
Nice! My pass side looks brand new, driver side,,, pretty ugly, Im thinking one was replaced. Driver side is taking on a lil internal moisture, not terrible, but not great either. Tried to restore with my turtle wax kit, but I think the pads are worn down pretty bad. Anyway, nice job!
Old Jun 2, 2017 | 01:49 PM
GhostTL09's Avatar
that looks good. I need to do my wife's MDX headlights. Really need to get a good clean sand down.
Old Jun 21, 2017 | 08:55 PM
viperkorn's Avatar
I need to try the sanding because mine look like someone tried using way to hard a grit sandpaper on them. Not even sure I can get the scratches out.
Old Jun 25, 2017 | 04:33 AM
DogP's Avatar
I'll go ahead and pile on this thread... I did mine 08 Type S headlights today using the Meguiar's Heavy Duty Headlight Restoration Kit. The lights were really hazy, and it bugged me every time I looked at them. They look WAY better now... hopefully it lasts.
Overall, it was easy to do... the kit came with the sandpaper (1000 and 3000 grit), plus the polish and polishing pad, and a UV coating/sponge applicator. I cleaned the headlights, taped around them, then simply sanded down the headlights, polished with a drill, then coated them. It took about an hour... and the kit has WAY more than enough to do both TL headlights, so I did my 2000 Grand Caravan headlights too. They were horribly hazed, and turned out great as well (and I probably still have enough to do a few more headlights).
Pat
Attached Thumbnails Headlight restored-20170624_150217.jpg   Headlight restored-20170624_171027.jpg   Headlight restored-20170624_150230.jpg   Headlight restored-20170624_171019.jpg
Old Jun 29, 2017 | 08:20 AM
LoveMyTL-S's Avatar
How long have you had the film on?
Old Jun 29, 2017 | 08:25 AM
LoveMyTL-S's Avatar
Some nice looking headlights!! Great job. I need to do mine also.
Old Jul 8, 2017 | 12:20 PM
WDPanda's Avatar
How long have the results been lasting?
Old Jul 8, 2017 | 02:28 PM
DogP's Avatar
2 weeks and going strong here. :-P
Pat
Old Aug 12, 2017 | 12:46 PM
CTucker's Avatar
I am assuming you wet sand them? Or do you do it while dry?
Old Aug 12, 2017 | 01:38 PM
Wet..
eastcoastguy
Mar 24, 2018 12:06 AM
anx1300c
Apr 15, 2017 07:39 PM
Dejan13
Oct 28, 2016 10:50 PM
genuwinecassius
Aug 1, 2002 11:32 AM
