First new mod for 2008
Specs...
Wheels: 5Zigen Proracer ZR+520 - 18 x 8.5 +38 (Chrome Silver)
Tires: Good Year F1 AllSeason - 245/40/18
Lugs: Project Kics R40 1.5 Extended
TPMS: Transferred OEM sensors. Strap bands and brackets used.
Suspension: Eibach Prokit & Koni Yellow (Stock perch setting) + SPC Camber
Review...
Tire shop told me that these GoodYear F1 AllSeasons are much wider than the other tires with same spec.. And it rubbed once on the way home with four sets of wheels and tires in the trunk and rear seat.
Thinking to raise few perch settings to give more room on the rear fender. Hopefully I don't have any problem until perches are raised.
Originally Posted by bigBLACKTL
looks really good!
Originally Posted by sT04Louis
NICE...cant wait for my wheels now.
Originally Posted by blkaspec
i dont comment on the WDPs much, but that wheel/paint combo looks sick
your purchase of the type s with aspec lip kit is already pretty hot!!
now with wheels and drop, you're pretty much set for 2008.
gotta get myself some JDM lugs!! where's a good place to get some??
Originally Posted by blue96813
Hi minkl81, I still haven't install the HTech I brought from you. I have koni adjustable shocks. Does your have 5 pinch? Where is all 4 shocks set to? BTW, how much did you get your lug nuts?
mine have 5 perch settings. its at stock height. middle perch i believe. gonna raise about 1 perch front & 2 perch rear this weekend
paid $130 for the lugs
Originally Posted by stillhere153
I think you are a pansie if you raise it...
no fat chicks
no fat chicks
now all four corners are rubbing on small to large dips on the road..
tires sit flush with the fenders and have no room for suspension travel.
+47 offset would've worked out better. huge room between the wheel and brake caliper with +37offset.
Originally Posted by Bearcat94
Those things are F'n expensive.
I think I'll get some (if I ever get wheels - ).
i think its bit overpriced too but had no choice on the extended lugs except project kics...
Looking at your pics again, the 5zigens look big for 18's.
As for the kiks...ill be getting the r40 neo-chro's once my wheels get state side
Think they are going for 180..
they do look bigger because spokes are fully extended.
i was going to get the neo-chros too but they didn't seem to match my chrome silver wheels. neo-chros were only $20 more.
I brought "Black" Ray Engineering Extended Lug Nuts for $129 shipped. I dont like open end.
that's exactly what i wanted. black rays extended closed. but they were backordered for 2 months
94 DC4 RS LSV/Turbo
if you are rubbing on all 4 corners maybe you should get an alignment because I don't think that should be the case... get them to camber your wheels slightly very slightly... and you will have wheel tuck so you can go lower
rolling on 245/40-18 18x8.5 +35 NEVER RUBS
