DRL Bulb Upgrade '08 WDP Type S
The I jdmtoy.com drl led kit I baught a while ago didn't come with very bright bulbs so I decided to go with vleds 6k white led bulbs the result was awesome.
Before
[IMG]http://i1303.photobucket.com/albums/ag143/kawalps1/20130125_221326.jpg[/IBefore
![](http://i1303.photobucket.com/albums/ag143/kawalps1/IMG_20130413_142315_zpsffa8f23f.jpg)
After
![](http://i1303.photobucket.com/albums/ag143/kawalps1/20130418_163035_zpsd34fd982.jpg)
![](http://i1303.photobucket.com/albums/ag143/kawalps1/20130418_163054_zps00ac03cf.jpg)
Old bulb
![](http://i1303.photobucket.com/albums/ag143/kawalps1/20130418_163818_zpsd78afc45.jpg)
New bulb
![](http://i1303.photobucket.com/albums/ag143/kawalps1/20130418_163842_zps5154cbf8.jpg)
![](http://i1303.photobucket.com/albums/ag143/kawalps1/20130418_164820_zps2e4ed183.jpg)
Before
After
Old bulb
New bulb
![](http://i1303.photobucket.com/albums/ag143/kawalps1/20130418_164809_zpsec8eb86f.jpg)
kawalps1 (04-19-2013)
They might but last I baught a yellow led it light up more amber then yellow you might be better of buying a 3k hid kit or just a normal bulb these guys have some awesome hid kits
http://www.theretrofitsource.com/store.php
Damn those look great!
sweet..are these plug n play? no extra stuff/resistors to get?
http://www.vleds.com/6k-white-10-led...45-1-pair.html
looks great! can you take some far away pics (10-20 feet)? i recently received my 5k lights from vleds but they sent me the 6 LED by mistake instead of the 10 LED. I'm going to send them back on monday but was thinking about getting the 6k version instead. curious to see how it looks farther away
Received 6,470 Likes
kawalps1 (04-20-2013)
They look awesome!
Lets see them outside during the day!
Here you go one link is for modules you will need two of these and other link is for the bulbs enjoy
http://www.vleds.com/new-improved-90...le-1-each.html
http://www.vleds.com/bulb.html?cat=1119
The bulbs I got are the 6k 10 led 9005 but there are different onesyou can pick the one u like
Actually u gotta buy 2 of the relays with the led bulbs link below
You will need 2 of these as well
Yes ill post some soon and reason I got the 6k is because iam about change low beam turn signals and fogs to 6k with zkw swap so it can match up nicely
Thanks,
Jon
Thanks for posting this. I ordered the bulbs when I read your prior post stating the harness was included. I now see you are mentioning we also need DRL modules. Do the bulbs come with the appropriate AMP connectors/harness to plug into that DRL module? I'm going to place another order for the DRL modules and anything else I'm going to need for this.
Thanks,
Jon
Thanks,
Jon
No you do need the modules the bulbs wont turn on without sorry I misread your question earlier so I didnt mention this but the reason I just baught the bulbs from vleds is because I originaly baught the kit from ijdmtoy.com so I already had the harness in place I just didn't like the bulbs it came with so then I switched to the vleds bulb but now I also realized the the vleds modules are way easier to install the harness from the ijdmtoy so that's y gave that link let me now how it all turns out cause I might replace the harness with the modules
Thanks,
Jon
![Smile](https://acurazine.com/forums/images/icons/icon7.gif)
How would that DRL module work with the bulbs you purchased? The LED bulbs look like they have the same connector as the stock bulbs but that DRL module has an AMP connector similar to an aftermarket HID kit. It sounds like I would need to buy a harness as well?
Thanks,
Jon
Thanks,
Jon
I will check it out I need some idea's
So if you get the vleds 9005 module it would plug into your stock harness and then u would just plug.the led bulb into the other harness coming out of the module its pretty simple but if u get the ijdmtoy harness you would have to connect the positive to the battery the ground it and then u have to hide the wire and run to the other side its a lot more work
From VLEDS re: the 9005 DRL Module:
DRL Module
The module will provide full power to the LED bulb when installing in a low voltage DRL system. Works with most vehicles using 9005 bulb for DRL/High Beam. Reverse polarity protection, if it does not work just flip the input connection around.
Some vehicles may require resistance on the circuit in order to function. Installing a pair of resistors will solve any low resistance issues like bulb out warning or bulbs not coming on. In this case our 9005_INLINE_RES may be the solution for you.
I think I was confused because of the yellow/black connector coming out of the DRL module ...I didn't think that would fit into the LED bulb for some reason. oops! If we go this route we may need a resistor as well.
DRL Module
DRL Module
Ya u might need a res
[QUOTE=kawalps1;14440606]Ya u might need a resistor but just plug all in once u get u and if it turns on u should be good but otherwise u can get a resistor from a auto store
Ya u might need a res[/QUOTE
Damn I guess this is kind complicated as well u know if u haven't ordered these module I think just do what I did vled bulb with ijdmtoy harness here is the link for the harness cause this has the resistor built in
http://store.ijdmtoy.com/LED-Daytime...decoder-01.htm
jon2000 (04-22-2013)
Ha ha i didn't even know home depot has a chin spoiler but I got it from ebay here is a link
http://item.mobileweb.ebay.com/viewi...id=25515567706
Here is a link
I emailed vleds about the inline resistors link on their page being dead. I received this response: Very sorry we do not have a live link for the inline resistors at this time. We are in the process of making a DRL kit for the TL. Please check back.
I'm waiting to hear when this will be released and if it will come with the 9005 DRL modules that don't need to be connected directly to the battery.
Jon
Jon
Jon
Jon
http://www.jlclightings.com/ProductD...Code=001125-12
Kawalps, let me help make your life on AcuraZine a whole lot easier!
In the lower right hand corner of each post, the middle icon is a Multi-Quote Button. It allows you to reply to more than one person in a single response. That will make your multiple responses look like all the posts I've merged for you. This way, you don't have to respond to each person in a single posting.
Give it a try-you'll thank me later!
takin care of Business in
Received 4,732 Likes
HOLY HELL...they look great...well done....
kawalps1 (04-24-2013)
![](http://i1303.photobucket.com/albums/ag143/kawalps1/20130423_210352_zps48bc7e9a.jpg)
![](http://i1303.photobucket.com/albums/ag143/kawalps1/20130423_210554_zpse7df0365.jpg)
This is like 5feet away
![](http://i1303.photobucket.com/albums/ag143/kawalps1/20130423_210337_zpsefe1d126.jpg)
And this one is like 10feet
![](http://i1303.photobucket.com/albums/ag143/kawalps1/20130423_210409_zps2efe2473.jpg)
Another close up
![](http://i1303.photobucket.com/albums/ag143/kawalps1/20130423_210458_zps06bae6e0.jpg)
sockr1 (04-25-2013)
Nice updated pics.
kawalps1 (04-25-2013)
