Desert Mist TL Build
#163
grabbed these illuminated reflectors, hope to mount them right above my exhaust cut out. the exhaust cutout on the type-s lip is about 240mm wide. these are 220mm, so it should fit. only issue is getting them flush without cutting too much from the lip--ideally just two holes for mount screws. these will be on with parking lights at 30% brightness and 100% brightness on brake light.
#165
nothing new. wrapped the top of my trunk and roof gloss black. the paint on the trunk was chipping from a bad paint job so i sanded it off and wrapped it. had extra vinyl and wrapped my license plate trim. the roof took 3hrs...so many weird curves and the vinyl bunches up in corners. the trunk took 20mins..
also installed some VIP puddle lights, been looking for a particular set that has concentrated circles and not a lot of bleeding light. wired to my dome supervision wire so only on with unlock and door opening.
as she sits now.
as she sits now.
#166
Looks great man! Few questions about doing the roof:
1. Did you remove any of the moldings? And did you wrap the antennae or paint it?
2. How much vinyl did you get? Will a 5x5 roll get it done?...or did you go with 5x6 or even 5x7?
I'm curious because I'm hoping to take a crack at doing this soon. Thanks in advance
#167
5x5 will be too short
DarkTower19 (09-05-2017)
#169
haven't updated this thread in a while but have the following in the works
As she sits now on 19" Volk te37 235/35/19 tires +43 front and +18 rear(25mm spacer is on)
- BC Racing Coilovers - Extereme Low edition 12k 6k
- Insane drive shaft axles (getting vibration at low speed)
- Brembo calipers, spindles with Centric Hi Carbon rotors - Rebuilding with new seals,and brake lines and repaint them HKS livery
- New wheel bearings and ball joints
- DC5 Type-R Recaros
- Wedge bracket/rails
- New plastidip - Frozen Blue - Prob dip end of year or beginning
#175
#177
Just swapped in the brembo spindles
All that's left is waiting for my wedge rails and sliders to install my DC5R recaros and throwing 15mm spacers all around. Should be good for year.
Happy Holidays!
- Brembo spindles with ARP extended studs
- Brembo calipers painted in HKS livery with VHT high temp paint, link to how i did it
- New OEM wheel bearings
- New OEM ball joint bushings
- New OEM sway bar end-Links
- New OEM compliance bushings
- New OEM caliper cross spring clip
- New OEM caliper bleeders
- New OEM caliper hardline
- New OEM Brembo brake soft line
- New OEM caliper bolts *Corroded caliper bolts eat threads on calipers
- New OEM caliper piston dust seal
- New Stoptech/Centric caliper piston fluid seal *Acura doesnt sell this. CENTRIC #14363023 x2
- Akebono ceramic pads
- Centric Hi-Carbon rotors
- Insane Drive Shaft Axles
- BC Extreme Low Coilovers with swift springs 12k F/ 6k R, 18/32 dampening F, 22/32 dampening rear, 2" all around
- Alignment, 2 degrees negative in front, 2.5 negative in rear, 0 toe
Happy Holidays!
Sarlacc
Console & Computer Gaming
09-30-2015 02:15 PM
AcuraKidd
09-25-2015 11:18 PM
09-25-2015 06:14 PM
STL TL-S
09-23-2015 08:52 PM
