3M Headlight Restoration Kit - '07 TL
Old 09-24-2015, 01:02 PM
  #41
rockstar143's Avatar
Received 19,994 Likes on 14,502 Posts
I don't think so, man...I have the embedded cracks (from age, or heat...)
Unfortunately, the kit won't resolve that.
Old 09-24-2015, 01:35 PM
  #42
kocyk123's Avatar
Sorry to hear that..
Old 09-24-2015, 02:41 PM
  #43
Me too!
Thanks, man...
it's not that noticeable...
Old 09-24-2015, 06:52 PM
  #44
LogicWavelength's Avatar
<p>anyone can polish...what OP is doing is going above and beyond by preventing it happening again...</p>
I didn't seal mine when I did it earlier today. I have a friend who did his car like a year ago and the lights are still clear. If after a year I gotta do it again then maybe I'll get a sheet of clear bra and cut it out - but then without wrapping the corners that will peel too. So I think I'm ok with polishing every other year unless they get super gross super quickly.
Old 09-24-2015, 07:45 PM
  #45
I will warn that I do think that over time, the more you polish, the heat will degrade the plastic to the point of being so thin it'll get the little cracks. I would seal them permanently ASAP. In South Florida, sanded/polished and unprotected will be yellow again within 3 months.
Also...wetsanding/polishing TOTALLY removes the oem uv coating that got sprayed on at the factory so if you've buffed, you've removed everything that was helping the cause. OP shows just the start of the wearing of the UV coat in front of the DRL bulb...once you even that out, it's totally exposed plastic.
I've researched and tested this ad nauseum because it's a big problem here and a personal pet peeve.
Old 09-25-2015, 05:24 AM
  #46
I just exhausted my car budget until the holidays. Would you suggest some sort of clear spray paint? Or 3M clear bra is the best way to go?
Old 09-25-2015, 09:23 AM
  #47
Hmmm...supposedly opti-seal will do the job...but I'm leery of long term, probably will slow it down to the point of not coming back if you reapply though...about $70 for that.
I'm sure the 3M stuff is great, but over the years, that'll yellow too. I did clear over the lens and didn't like how it looked, maybe I didn't buy the good stuff...who knows.
I do this blue magic headlight lens protectant...but I don't think it'll stop it forever either...I reapply every time I put tire shine on...let it bubble up while I do the tire shine, buff off.
Old 09-25-2015, 11:08 AM
  #48
Oh ok! That is doable. I'll sneak it past the wife in with the rest of my car care chemicals then.
Old 09-25-2015, 11:26 AM
  #49
LOL>..I know all about sneaking past the wife. Where you won't lie if asked, but you try and avoid being asked in the first place.
Old 09-25-2015, 01:51 PM
  #50
"Yea honey - I used to use this stuff before. It's just that I don't use a lot so the bottle lasted a few years."
Old 09-25-2015, 11:13 PM
  #51
I get the shaft either way, our amazon prime goes to her email address...
Old 09-25-2015, 11:37 PM
  #52
kocyk123's Avatar
I ended up working on my girlfriends 07 TSX today. I did driver's side and here are the results:
Before:
After sanding:
After wet sanding:
After polishing:
Comparison (Sorry for blurry pic):
As you can see the left side got its pure white color back. You can clearly see the cutoff line and light is not diffused compare to the right one:
Before and after:
I will do passenger's side tomorrow. My girlfriend is currently in Europe visiting her family so I thought that I will detail her car and make it look and feel brand new :-)
rockstar143 (09-26-2015)
Old 09-26-2015, 11:31 AM
  #53
Atlas_Gen's Avatar
Don't forget to use some kind of sealant after you wet-sand and polish it. I used Meguiar's Headlight Protectant after restoring my headlights although I just used the Meguiar's PlastX Cleaner & Polish by hand instead of wet-sanding it and there was only a slight haze a little over a year so I just cleaned and polished it by hand again but I'll have to try my DA polisher on it next time.
Old 09-26-2015, 12:09 PM
  #54
kocyk123's Avatar
I put 3m hood bra film on it right after polishing
Old 09-26-2015, 01:55 PM
  #55
how hard would you say application of the 3M stuff is? is it a bitch to clean the glue after it yellows in a few years?
I tried doing a clear over but it looked ugly. I think I used cheap stuff though.
Old 09-26-2015, 03:53 PM
  #56
kocyk123's Avatar
I have never tried removing it so I don't know the answer.. ;-)
Old 06-08-2016, 11:03 AM
  #57
kocyk123's Avatar
Did another restoration. This time it was my neighbour's car. Left one is after restoration with 3m hood bra film on it. It was as bad as the right one:
Let me know if anyone in Chicago area needs to get it done. I do this for free (you just cover the material cost - $15 for the kit and $19 for the 3m hood bra).
Old 06-08-2016, 07:44 PM
  #58
Steven Bell's Avatar
Received 6,470 Likes on 5,162 Posts
Looks good.
Old 06-12-2016, 09:37 PM
  #59
RIP RBP
upnout's Avatar
big difference my HL's look like crap
Old 06-15-2016, 01:45 PM
  #60
kocyk123's Avatar
They do look nice and also your visibility at night is improved a lot.
Old 10-09-2016, 11:48 PM
  #61
Si_jeff's Avatar
Hi, wanted to ask how hard is it to do the 3M clear bra after the wet sanding and polishing? Since the 3M is not precut, is it hard to do? Was thinking of Lamin-X but the 3M stuff is a lot cheaper and you get a big roll.
Old 10-10-2016, 09:57 AM
  #62
breakpoint's Avatar
I was thinking the same thing. do you precut the bra or do you install then cut off the extra? Headlights look great!
Last edited by Steven Bell; 10-10-2016 at 09:51 PM. Reason: No need to re-quote the previous post, especially if you're the next person posting.
Old 12-07-2016, 08:35 PM
  #63
Asianemia's Avatar
in for the update on bra
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
rockyboy
09-29-2015 12:05 AM
AmplifiedDetails
09-24-2015 02:55 PM
Quick Reply: 3M Headlight Restoration Kit - '07 TL
