20x10 SSM Concave FTMFW! SSM
#82
I thought about getting these wheels also. The same exact style as the VMR V710's are the Avant Garde 310 which are low pressure cast wheels so they are stronger then the VMR's, which are just gravity cast, which means they won't bend as easy. I know that these are for the 370z but the fronts are 19x9.5 +22 and I was going to see about getting them milled to +35 if I could.
http://www.modbargains.com/Avant-Gar...els-Nissan.htm
Hey OP, how much did you get yours milled??? You know the offset now? Also are these low pressure cast rims? THANKS!
#84
SHAWD 04TL is in
This was the look I was going after. WHAT DO U GUYS THINK... HOW CLOSE DID I GET?
Obviously I didn't want to spend the $6000 for HRE's (with tires) so I got the closest wheels I could find, then went through all the trouble of borring bolt patterns & modifying offset etc. I think after it comes out of the body shop, I will maybe add some spacers in the rear... but I dont know yet, cuz I don't have my camber kit yet.
Here is the link for those out of the loop:
http://www.vividracing.com/catalog/i...0-p-86509.html
After all costs I think I came in at about half of the cost of the HRE P40s
#89
Damn those wheels are sexy. Great choice
#92
They make these exact same rims by Avant Garde and they are the M310's. I just ordered a set for my Mitsu Evo 9 which is 5x114.3 as well. Hey Roger they do make these in 19x9.5 5x114.3 but they are for the 370Z and the offset is +20!!! Very aggressive for the Evo but WAY to much for the TL. You would have to mill the hell out of them! I guess you got the +35 5x120 and had them make it to 5x114.3
How did that turn out???? Any wobbling while driving? Any problems that you could explain with doing both drilling and milling??? I was very curious about the drilling of the bolt pattern to fit process.
Thanks for the knowledge!
#94
SHAWD 04TL is in
Yes they do come in 19s +20 offset (not 20s), but realistically you can only shave off about 4.5mm off the back pad, so you are going to have to pull & mold fenders for them to fit, with an offset of about 24.5-26. WOW!
#99
looks good looks good...seems a bit much for the TL perhaps? just my opinion I guess, but it seems like those work way better with a porsche or e92, the body lines on a TL aren't as aggressive I think
but still looks good, don't get me wrong
#112
Just kidding! I'm anxiously waiting to see the pictures though.
