XLR8 J-Pipe Installed, now vibration?
Took delivery of excelerate's j-pipe and installed it next day. Dam the car freakin pulls now. Billy Boats done a great job on the welding, very clean and fitment is perfect.
After i put on the j-pipe i noticed a very strong vibration when in drive or reverse. I thought it needed to be warmed up..i drove around a bit, even at stop lights i'm getting the vibration. You guys think its the stiffer flex section/pipe restricting the motor from moving as much?
I always had a vibration at a stop light, but not this bad...I hope its not the engine mounts...i was going to buy a tranny cooler with my next check )=
94 DC4 RS LSV/Turbo
is it the center console, if so could be the higher exhaust note +the vibration you were already feeling
i'd say get back in contact with excelerate and look into the purchase of the motor mounts because technically the tl has a pretty quiete cabin at idle/reverse
Former Sponsor
1. Bad mounts - since you already had a vibration
2. The j-pipe hanger isn't mounted correctly and is touching something.
3. Misalignment - loosen up the bolts and move the j-pipe around and make sure it isn't touching anything and then re-tighten.
No need to make a gasket; just use some high temp silicone on the flanges.
BoricuaTL
Apr 8, 2016 01:08 PM
ExcelerateRep
Dec 11, 2015 12:58 PM
nuldabz
Sep 3, 2015 05:49 PM
this jpipe is awesome! you won't regret your purchase
