XLR8 J-Pipe - Back in Stock!!!
BACK IN STOCK!!!
The XLR8 J-pipe is 100% stainless steel, utilizing T304 stainless steel. The primaries are equal length 2.25" piping which transition into a 2.5" collector with stainless steel flanges and hangers. Our test fitments have shown that the hanger is located in different locations so we have come with a bolt on style hanger to support the weight of the j-pipe. Here are the pics:
Here are the dyno #'s:
This is dyno graph a few months before showing the difference on the vehicle with the XLR8 catback exhaust for the TL-S:
This is the dyno graph showing the gains of the j-pipe. Dyno conditions were similar; in fact there was more humidity and a higher temp on this day so it might even make more power:
Peak gains were 7 whp and 16 ft lbs of tq to the wheels but this car was making tons of torque and hp in the lower to mid RPM range.
We also have XLR8 test pipes and high flow third cats available:
http://store.excelerateperformance.c...e/b-10668.aspx
does the stock manifold peice that bolts to the block flow adequet enough? just curious about the difference between the J pipe and a header other then the price difference.
For the CL you can get the entire system (headers):
http://store.excelerateperformance.c.../i-130510.aspx
Registered Member
Excelerate:
I've toyed with the idea of installing a J-Pipe in my '04 manual TL and have a few questions, if you don't mind.
If I decide to go this route, I would be keeping the rest of the stock exhaust in place and there are no other mods on the car - it is box stock. I noticed that you mentioned the greatest gains appear in the low to mid-RPM range and frankly, that is where most of us operate most of the time so those gains are the most useful. With an otherwise stock system, can one still expect your J-Pipe to give noticeable and useful gains for everyday street use?
Also, do you ship with all necessary components (gaskets in particular)? Is there any problem with ground clearance (remember, mine is untouched) or clearance with other undercarriage items? Also, I imagine that since the rest of the exhaust would be left as is, there would be virtually no increase in cabin noise - is this true? What about droning in the range where the harmonics most cause this between 1700 and 2200 RPM?
I'm not at all new to add-ons and modding> I've just held off because this car is really quite good as is. Just giving this some thought again, that's all.
Thanks,
SB
Thanks,
SB
Excelerate:
Thanks,
SB
Thanks,
SB
Yes you can. Of course, the more free flowing the rest of the exhaust the more power you will make.
Yes.
No. Our j-pipe has plenty of clearance unless you are slammed (2" or more).
Since you are flowing more exhaust, the exhaust note might get slightly louder but nothing significant.
None.
I don't usually lay into people, but that really is a pretty asinine question.
BTW Josh I'll be placing an order here pretty soon!
cision,
In my experience with the J-pipe, I did *not* get an increase in gas mileage. And, I do watch my gas mileage carefully all of the time.
But, I did feel an increase in performance. If you get the J-pipe, do it for the power increase and *not* for the gas mileage increase (which was non extant in my case).
WELCOME TO THE FORUM (well, at least to posting replies)
Seriously? We're not talking about florescent light bulbs here we're talking about a performance modification for a car. If anything your gas mileage overall will probably decrease because you're going to want to lay into the gas more to feel the power.
Inaccurate thanks for the welcome.
Just to clarify.
I did not get an increase in gas mileage that I could notice. This is based on watching my MID readout daily and keeping track mentally. I use my car only for commuting to work (consistent usage pattern = consistent avg mpg), which is approx 1 hour per each direction. I estimate it is equivalent to 2/3 City and 1/3 Highway.
However, it would be wrong of me to say that I had absolutely no increase in gas mileage. The MID reads MPG to the nearest whole number. I keep track mentally. My mileage could had increased by 1/2 or 3/4 mpg without me noticing. Plausible.
It might be an asinine reason for you but not for me. The primary use of my car is to drive to work. I drive 1 to 1.5 hours (depending on traffic) each way to work. Gas milage is a big deal. If i can improve my gas milage and make the car more fun to drive its a no brainer. If it reduces my gas milage then i probably dont want to do it.
IIDXholic
10-08-2015 07:53 AM
sockr1
10-01-2015 01:31 AM
