Where I can buy the HB pulley for SC
Hi guys, I had been plan to put SC on my car,and now I got the SC but my plan to put intercooler instead liquid to air cooler. I just brought the 7psi pulley and I had been searching around to get the pulley with 10psi. Is't any website or shop can make one for our SC, any input will be appreciated. Thanks guys
dont think that blower was meant to spin that fast!
Any FMIC will be work.... I think the max boost the blower can handle about 10psi... So I think will be fine, now I just need to find the pulley can push to 9 or 10 psi, any idea?
the blower already have issue with heatsoak and being over work stock. HB pulley just going to make it worst FYI. This is why Paul is using an M90 blower. Comptech use a M62.
https://acurazine.com/forums/2g-cl-2001-2003-50/max-boost-pulley-691099/
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/comptech-supercharger-high-boost-pulley-744367/
https://acurazine.com/forums/showthread.php?t=691099
https://acurazine.com/forums/showthread.php?t=744367
OP the max you say that the SC can handle is 10 psi; you never want to push that. That is why the HBP that we have now is 7-8 for safety reasons. Also if your motor isnt bulit to handle all that psi......boom bye bye motor. Do more research
Thanks for the input guys.... Yeah I don't have any problem right now, why I need HB pulley bc I will use the FIMC, if I use that I will lose some pressure or boost, so if I can get 9psi on pulley, my engine will be get like 7psi. I hope you guys understand what I mean.
I know the blower soak the heat,may be I will put hood scoop on it.
So any idea where the place can make it one?
Alright correct me please, I have two alternator pulley, one with 3" and the second one 3.5" which one i can get more boost if my blower pulley size 4"?
Btw thanks for the link, help me. A lot.
Chapter Leader (NY/NJ)
Asked OPEL who led me to the right ones. http://www.pulleyboys.com/store/prod...9&cat=9&page=1
Pulley offset should be .4 and not .9 as my first link. size should be 3.0 but I will confirm that later.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
