Well, today is the big day. (Last dyno run, first and last tune)
Here's all the info I have compiled for my 2006 Acura TL 5AT with 158k miles, stock transmission. Everything you need to know in one topic, since I can't figure out how the fuck to delete my other ones -
Mods:
AEM Cold Air Intake
ATLP V2 J-Pipe
JE Test Pipe
XLR8 2.5 inch Base Duals Cat-Back
Vibrant 2.5 inch Ultra Quiet Resonator - pending
RV6 Hi-Flow PreCat x2
Hayden Transmission Cooler - pending
J37 Intake Manifold
J37 Throttle Body
P2R J37 Throttle Body Spacer
P2R J37 Intake Manifold Spacer
P2R J37 IM Thermal Gasket x1
P2R J37 TB Thermal Gasket x2
Throttle Body Coolant Bypass
AEM Fuel/Ignition Controller
Pro-Tuned By JE Import Performance
Weight Savings:
Hood Insulation Delete (2lbs)
Weather Strip (above hood) Delete (2lbs)
Engine Bay Covers Delete (6lbs)
Spare Tire Delete (34lbs)
Rear Seat Arm Rest Delete (6lbs)
Rear Floor Mats (6lbs)
Trunk Insulation Delete (23lbs)
Lighter Exhaust Parts (30lbs)
Lighter Intake Manifold (8lbs)
Dyno Results:
Baseline No Mods:
205hp at wheels/258hp crank
3.25 Inch CAI/J32 TB Spacer/Hi-Flow Precats/J-Pipe/HF 3rd Cat/Catback:
225hp at wheels/279hp crank
J37 IM/J37 TB/HF 3rd Cat Delete:
230hp at wheels/286hp crank
J37 IM Spacer/J37 TB Spacer/TB Coolant Bypass/Pro-Tune:
???hp at wheels/???hp crank (today)
Parts removed/no longer needed and conditions of each:
OEM-Spec:
OEM Third Cat (Good)
OEM Downpipe (Fair)
OEM Intake Manifold (Fair)
OEM Intake Manifold Cover (Fair)
OEM Intake Manifold Cover Gasket (Good)
OEM Throttle Body (Fair)
Race-Spec:
ATLP Hi-Flow Third Cat (will need flanges, Fair)
P2R J32 Throttle Body Spacer (Excellent)
P2R J32 TB Thermal Gaskets x2 (Excellent)
My YouTube channel with every video for the car so far:
https://www.youtube.com/channel/UCXu...6gteAqtawIGq5g
Alright guys, let's see what happens today. At a bare minimum I hope my torque curve flattens out a little.
Mods:
AEM Cold Air Intake
ATLP V2 J-Pipe
JE Test Pipe
J37 Intake Manifold
J37 Throttle Body
Weight Savings:
Dyno Results:
Baseline No Mods:
OEM-Spec:
OEM Downpipe (Fair)
Race-Spec:
TacoBello (02-22-2016)
Good summary, will see how the final result is with essentially full bolt-ons.
Looks like about 25whp gain from everything except for spacers/TB bypass/tune. So we'll see how much the tune adds in terms of whp.
Very expensive $4000 for 25whp gain so far...so should be good reference going forward to others who want to mod base 5AT TLs and expected gains for the dollars spent
The 5AT TL loses 53hp from the crank to the wheels? ![what](https://acurazine.com/forums/images/smilies/what.gif)
Is it just me, or is that dyno reading a bit low?
Also it's been brought to my attention that I have oil leaking from my oil pan and VTEC seals. Subframe and oil pan are covered in oil and dripping to the ground. That's what they said anyway. I haven't seen a single drop of oil where I've been parked.
No point in dyno since nothing has changed enough to make it worth spending 100 bucks on a run. The tune can't be done today. I need the correct harness. FUCK ME. Oh well. It's gonna be a while till I have more money to finish the project.
Patience, young grasshopper ![Rice](https://acurazine.com/forums/images/smilies/rice.gif)
If you get it all done super quick, in six months you'll be kicking yourself for having nothing left to do to your car
enjoy the journey!
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
The technician was saying all that officially will be adjustable with the FIC is only air/fuel ratio. Nothing more. Nothing less. Guess I better start saving for that adapter harness....sigh
I have no oil spots when parked and have always had to fill up oil, but when I got my TB job done they mentioned that leak. i told them i don't see spots parked and they said it mostly comes out under pressure when driving.
Yeah the car drives amazingly well and not a single engine problem. Stock acceleration times were better than advertised back when I first bought it but I can attribute that to the BFGoodrich GForce Sport Comp2 tires, I will definitely be buying those again.
