Vtec controller
Old Nov 22, 2007 | 06:38 PM
Ac_Attack's Avatar
Not your moms TL.
Vtec controller
So when I searched I found that noone has got one to work with the 3G TL....something about not having a tach signal wire so it engages at idle. Has anyone used an autometer tach adapter? My mustang buddy had the same problem hooking up a tach in an 03 Mach 1...no tach signal wire b/c of the modular motor...could this possibly fix the problem the 3g is having?
Old Nov 25, 2007 | 07:53 PM
Ac_Attack's Avatar
Not your moms TL.
i guess noone has tried this?
Old Nov 25, 2007 | 09:12 PM
JamminTL's Avatar
B A N N E D
When we did my Dyno we hooked into a tach signal wire...?
Old Nov 25, 2007 | 10:02 PM
mishar's Avatar
What is the point of installing that controller?
Old Nov 25, 2007 | 10:31 PM
BLACKURA_NY's Avatar
I have car ADD
vtec controller would be sick for a TL, especially a 3.5
i dont think thats why we cant use it... ive researched this before a while back... i think maybe something with the Drive By Wire??
would be nice.. especially for boosted TL's... you can change the VTEC engage RPM's...so if you drop it from ... (4600~4700 stock) to 3000rpm you can increase low end power and get quicker 60' times and 0-60...
Old Nov 26, 2007 | 06:14 AM
05AcuraTL916's Avatar
yeah im pretty much interested in this my friend told me to get one but i dont know about it so hopefully someone did it and would give some good feedback please
Old Nov 26, 2007 | 09:23 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
[QUOTE=BLACKURA_NY]i dont think thats why we cant use it... ive researched this before a while back... i think maybe something with the Drive By Wire??QUOTE]
^wat he said
Old Nov 26, 2007 | 11:09 AM
Ac_Attack's Avatar
Not your moms TL.
whats the deal w/ the DBW? how does that affect it?
Jammin, when I dyno'd that had the coil wire reader looped around the set wires foe cylinder 1, instead of an actual coil wire on an old ignition system,
but what i get from searching is there isnt a direct coil signal wire sice it has 6 coils so the controller wont get a signal, hence it engauges at idle...IF thats the case the tach adapter should work....im looking into this pretty hard so if theres anymore input from the ones who have tried it i would appriciate it!
Old Nov 28, 2007 | 05:03 PM
mishar's Avatar
Originally Posted by BLACKURA_NY
…you can change the VTEC engage RPM's...so if you drop it from ... (4600~4700 stock) to 3000rpm you can increase low end power and get quicker 60' times and 0-60...
It won’t work like that. VTEC switches between two camshaft profiles. One, opening valves lower and shorter, is for low RPM and the other, opening them higher and longer, for high RPM. If you switch between them at lower rpm you will loose power.
Old Nov 28, 2007 | 08:13 PM
I have car ADD
so then what do you actually use this controller for? i thought it was for simply choosing when VTEC engages/disengages or longer hold time
Old Nov 28, 2007 | 08:46 PM
Ac_Attack's Avatar
Not your moms TL.
Thats what I was under the impression of too.
Old Nov 28, 2007 | 09:10 PM
I have car ADD
keep us posted.. once ive got all my bolt-ons attached, i wanted to look into this and/or some ECU work
Old Nov 29, 2007 | 11:51 PM
mishar's Avatar
You are right, but problem is that you can not choose better moment to engage VTEC than factory already did, unless you change camshafts, intake valves, intake manifold, camshaft gears or so. If you change some of those it could be that ideal switch point is at different RPM. Than this controller would have sense.
Old Nov 30, 2007 | 12:36 AM
spiike's Avatar
Isn't Infiniti's VQ engines basically a form of vtec throughout the RPM range? They are heavily advertising variable lift on their cars. Why can't we implement that with our engines?
Old Nov 30, 2007 | 02:21 AM
well since u mentioned about cam gears can u even change the tl camgears because itsnt it only 1 camgear or can u switch it to make it quicker??
Old Nov 30, 2007 | 06:07 PM
mishar's Avatar
I don’t know how that VQ system works, but VTEC has camshafts with two different lobes for low and high RPM (TL only for intake valves). Switching point is inherent to camshaft and the rest of intake system, so unless you change something significant there switching point shouldn’t be changed.
knight rider
Mar 4, 2016 08:59 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
adreano17
Sep 29, 2015 08:48 AM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
Brandle34
Sep 23, 2015 07:20 PM
