UR Pulley User Feedback
Hey guys. I know quite a few of you have been using the UR pulley for awhile now and want to know if you've had any problems. Let me know a couple things, like what your driving habits are like, how many miles you've had it on and what kind of problems you've had.
I only ask, because I got mine delivered about two weeks ago and am planning on having the dealer install it for me this coming week. I'm still a little nervous about it messing something up with the engine though. Please give me any feedback you have. Thanks in advance!
As long as you get the UR one that is balanced correctly and it is installed right, you shouldn't have any problems. The only problems I have heard people talking about are a vibration in the shift knob.
If the dealer is willing to install it- along with the new correct belts, then they have the proper tool to hold the engine still while they apply 181 foot pounds of torque
Most probs can be traced to failure to torque to spec
Had it installed 9k ago with stock belt in use. MPG has been consistent but i have had a misfire code with the stock belt. Im not sure if thats the reason why but thats the only thing that has came up. CEL flashes under hard driving.
I got a UR pulley waiting to go in, also....People keep telling me it might be reverse threaded-in (Clockwise to unbolt). This true? Gonna get it pro-installed cuz I don't think my arms can put out 180 ft lbs of torque! just wanna make sure whoever I take it to, knows which way to turn it.
The only solutions I have seen is using the inspection port on an 5AT and 6th gear/friend on the 6MT.
I've had mine on since March (over 5K miles so far)... no strange vibrations or any other problems aside from how much of a pain in the ass it was to put on. I posted my initial impressions in another thread but to sum it up power is delivered smoother and a little quicker. It's been on so long now I don't even notice it anymore - sort of like the Comptech Short Shifter. I'm not saying that it's as good a mod as the SS, but I'm happy with the result.
BTW - I went wish the stock sized pulley.
Anyone terribly concerned about damage should simply install a different mod to their car.
This one is fine and helps the car a bit- but at the cost of you losing sleep wondering if 5 years from now............
If the dealer SELLS you a part and installs it, they guarantee it does not affect warranty or the parts maker has a deal to honor warranty thru the dealer for their part
Thats how the dealers can mod so many cars brand new on the lot
and sell it with full warranty
Thanks for all the input guys! I now know that I'm going to have it installed.
I'm gonna call the dealer tomorrow and see what they say about installing it. I'll let you know what comes of it. If the dealer won't do it, I know of another shop in town that works solely on honda/acura cars and specializes in "tuning" NSXs.
If I understand 01tl4tl correctly, he is thinking like I do; dealer warranty's the work, manufacturer warranty's the part.
i have been getting the vibrations in the shift knob, usually @ 4500rpms or higher. wasnt sure it was from the pulley until you guys said something. great mod for $200 bucks. not sure if there are really any whp+ gains
The purpose of the underdrive light weight pulley is to free up a few HP lost in turning the AC and other pumps- plus the reduction of spinning mass on the end of the crank-
from 8 pounds down to less than 2!!!
see www.unorthodoxracing.com for tech info
It doesnt increase HP- just releases blocked power already in the engine
and makes car go faster sooner!
Well, unfortunately, I called the dealer today and they said they no longer install aftermarket parts, because they've been burned on it in the past.....that sucks! I'm gonna have to try and find another shop to do it, because I don't have the tools to do it. I have a friend, who's dad might be able to help me out though.....he's got a nice little shop setup.
Being 4500rpm or higher, that's faster than cruising rpm's, but I would think a pulley inducing vibrations would cause some kind of eventual damage.
hhmmmm great point... but nobody has had any horror stories yet of the pullies....
the vibration i get is in the shift knob (5AT) and i check today, its actually over 5k rpm and its not tooo severe
Is your pulley held on with 181 ft lbs of torque??-
thats the first thing to know for sure- has to be on tight
You can find Acura specialist shops or import sports shops in every town-
look in the yellow pages - a real phone book not the internet
Check parts store parking lots for Hondas and ask the employees where to go
Its easy if you have the right tools and a pain worth paying 60-100 bucks to let a pro do right for you
i had my mechanic do it... i know when he did my TB spacers, he torqued it properly.. i think 18lb/ft... can i just buy a cheap torque wrench to check this? i dont know if he tq'd it right... everything seems to be fine. just a lil driveline vibration in the shifter @ high rpms...
i am only assuming its front the pulley, as mentioned earlier in the post... + its the only mod i have done in the past 2 months, when the vibration starting. i seldom notice it...
Have any of you guys had yours installed at acura specialist shops? There's one that I'm considering going to, but not sure just yet. Any recommendations on what to ask them?
Former Sponsor
Former Sponsor
Josh - while you are here- what tool do you suggest for installing to the proper torque or at least somwhere close to enough?
My Garage not
i'm confused. is the torque to install the UR pulley 181 ft lbs, the same as the stock one?
i know i saw on this forum a while back that it was something like torque to ~60 ft lbs and then tighten 45 degrees. i've had the pulley sitting in my room the past 6 months lol, i need to head to the shop.
Love mine, I've had it on for about 5k miles. I have a very similar engine so I figured I'd post here. UR will probably go on my next car.
I got installed at a local honda/acura specialist for $75.
wasup
thats the alternate procedure for those without a big torque wrench
Which is worse- finding the right tool or trying to set it by degrees past...
Thats like oil filters!!
This really is a job for shop with a lift. compresor and a couple special honda tools so you dont screw up the flex plate, or over or undertighten the all important pulley bolt!!!
Most shops will charge $60 to $100 for the complete install
Your looking at $60 to buy the right tools not including the torque wrench that goes to 200+ ft lbs
Some things are just a wise investment to have a licensed insured responsible party take care of it for you.
My brakes, oil, spark plugs, wheels- things like that I do myself
Pulley is one to pay someone else
Struts and the spring compressor- my emergency room deductible is higher than the cost of subletting at least that part of that job too!
Former Sponsor
Thanks for all the info and advice here guys. I didn't get around to calling the shop just yet, but hopefully I will be able to call on Monday. I don't think they are open on the weekends, but i could be wrong.
MrHeeltoe
20
02-23-2023 01:54 PM
calrow
05-03-2017 10:21 PM
SinCityTLX
55
10-11-2015 01:20 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
