UR Pulley
Old 01-23-2007 | 08:08 PM
THTL's Avatar
Question UR Pulley
is it worth getting the UR pulley for an AT TL. what is the different between the OEM and the UR one that make it gain the power.
Old 01-23-2007 | 09:05 PM
jonathan.chance's Avatar
07 NBP TL-S
biggest difference is weight reduction - You may have some better answers if you do a search in the Performance Parts & Mods section for "unorthodox under drive pulley"
Old 01-23-2007 | 09:49 PM
3rdGenA-spec's Avatar
the pulley is just like a lightweight flywheel. no real hp gain. just less rotating mass to turn. which lets the engine turn faster.so you build power faster.
Old 01-24-2007 | 09:42 AM
AnothaTL's Avatar
I'm your huckleberry!
I checked out with unorthodox and they do not have one for the 3rd gen TL.
Old 01-24-2007 | 10:48 AM
lembowski's Avatar
Trucki!!
Then whats this?
Old 01-24-2007 | 11:42 AM
A SiQ TL's Avatar
Mods, can we get a section in the 3g garage on pulleys?
https://acurazine.com/forums/showpos...6&postcount=14
Old 01-24-2007 | 01:27 PM
07 NBP TL-S
lembowski...
a little harsh but
Old 01-24-2007 | 01:46 PM
lembowski's Avatar
Trucki!!
Originally Posted by jonathan.chance
lembowski...
a little harsh but
Not harsh.............I would have linked him to it, but there was no direct link on the site as you can see.
Old 01-24-2007 | 02:27 PM
Excelerate's Avatar
Former Sponsor
UR does offer an underdrive pulley and a stock size pulley. You will notice that hte car revs out quicker. It usually is good for a 7-8 hp gain.
Old 01-24-2007 | 07:04 PM
07 NBP TL-S
true - true
Old 01-24-2007 | 09:35 PM
keepin_it_clean's Avatar
TL on 20's
I have the stock sized UR Pulley and I love it. The weight difference is nuts and you feel it in the car too. Gains are the best for the $$$ Talk to Excelerate he will help you out
Old 01-24-2007 | 10:37 PM
AnothaTL's Avatar
Then whats this?
Enough said! Thanks!!!
Old 01-25-2007 | 11:37 PM
LexOr's Avatar
I'm looking to get this mod soon,
But I have a question.
What is the difference between the "STOCK DIAM." Ultra Sc & the "UNDERDRIVE" Ultra S?
Which one will get me more power or allow the car to go faster because of the weight loss?
Thanks guys
Old 01-26-2007 | 08:07 AM
kjelly's Avatar
v 4910shp/19,600ft-lb v
The "Stock Diam" is the same size as the stock pulley. Where as, the "Underdrive" underdrives the accessories slightly by being smaller in diameter....
Both are a reduction in weight; the Ultra S will give you a slight increase in power versus the stock-sized one since it's smaller. This is granted you don't have a sound system req. more than 600 watt RMS or a supercharger. In those cases, an underdrive pulley will produce adverse effects.
Old 01-27-2007 | 08:22 PM
bigmoetl1's Avatar
wdp skyhawk
I you are not buying a system get the underdrive if you have a big system get the stock ur pulley either way you will gain horsepower
Old 01-31-2007 | 02:55 PM
Bochsita's Avatar
4th Gear
Wink
In regards to the UR pulley I have these questions if anyone can help:
1. Does a stock sized UR pulley have the weight reduction to make a difference, and if so about how much HP is the difference?
2. What is the down side of going with another size pulley? Do potential problems extend to fully loaded vehicles even without a SC or 600w stereo as stated above?
3. Would a larger alternator correct this?
Please help me understand. I'm interested in the part but I want to be sure it's situationally appropriate for my car.
Old 01-31-2007 | 05:07 PM
Black_05_TL_6SP's Avatar
Ryan Christopher
1. Yes, there is a huge difference in weight. The stock one is steal with a rubber insert, while the UR one is billet Aluminum. Much lighter( stock dia. or underdrive)
2. When sitting at a light your air will not be as strong, your alternator will not charge at 14 volts but rather 12.5-13, and power steering will be slugish at idle.
3. NO, as its not the equipment, its the pully diameters. The speed of the pulleys turning has changed.
Old 01-31-2007 | 05:11 PM
TL on 20's
Old 01-31-2007 | 06:13 PM
Kennedy's Avatar
OMGWTF4THGENTL
Right...
The underdrive pulley is smaller in diamtetr (slightly), thus it turns your accessories slightly slower. MOST of your power is gained from the reduction is weight (stock or undersriven), and the underdriveing accounts for the equivalent of 1HP (15% of your HP gain comes from underdriving according to UR).
2) Negatives? Turning your AC compressor slightly slower will cause it to be slightly less effecient (won;t cool as well), which may be noticeable at idle.
The power steering pump being turned slightly less may cause slight "binding" at idle, where the steering binds for a second (as the pressure build up again) while turning. Given the lack of steering sensitivity on the TL, I don't think this will ever be a problem.
I've only READ about these potential issues, and have never read anyone here complain about them. Some think there might be engine bearing risks with running these, but most are of the opinion that thisis not an issue.
3) You don't need any additional equipement to run the pulley. These issues described are testbook, and given the number of folks using them, I don't think you'll ever notice.
There may be an upside in that the undersriving of the accessories may actually preserve them a few extar thousand miles. Less cycles = less wear... again, another theory.
Old 01-31-2007 | 07:22 PM
aryathegreat's Avatar
Is that for the smaller diameter pulley or the stock sized one thats just lighter?
Old 01-31-2007 | 08:07 PM
Kennedy's Avatar
OMGWTF4THGENTL
They're both way lighter guys.
Do some searching and homework on these. This concept is not new, and this has been discussed many time before.
Smaller diameter pulley = underdriven... Hence the AC compressor is being "under-driven", not using full power to crank the AC but reusing that power to "go".
Old 02-02-2007 | 01:22 AM
Excelerate's Avatar
Former Sponsor
I think the underdrive crank pulley for the 3rd gen TL is 14 oz and the stock size is 16 oz. The gains will be very similar between the 2 pulleys.
Old 02-02-2007 | 12:15 PM
Ryan Christopher
Only for the under drive pulley. The stock size is still turning all the other pulleys at the stock speed. The weight difference just means there is not as much of a load on the motor. It will actually idle better (in theory).
Old 02-03-2007 | 12:39 AM
Jzuse's Avatar
So in theory if there is not as much load on the motor, when you do get on it its going to have less weight so it'll spin faster, so you'll build power faster right?
Old 02-03-2007 | 12:45 AM
Ryan Christopher
Correct, less rotating mass, therefore the power being produced by the engine is used to propel the car forward, rather then turn the heavier crank pulley. This is the same principle with a lightweight flywheel.
Old 02-03-2007 | 11:13 AM
neef's Avatar
Real Estate Investor
could I get a quick part number?
07-16-2017 08:33 AM
mrkingstonvi
02-22-2016 02:53 PM
thegipper
10-21-2015 08:19 AM
iCrap
09-11-2015 07:21 PM
Quick Reply: UR Pulley
