TLs CAmshaft In
Old Mar 13, 2009 | 09:31 AM
  #41
Escobar7's Avatar
about 150 if i remember correct
Old Mar 13, 2009 | 09:32 AM
  #42
Escobar7's Avatar
each
Old Mar 13, 2009 | 09:36 AM
  #43
Maddizm's Avatar
^ They're two? Aren't our engines SOHC? Well isn't the base TL SOHC?
Old Mar 13, 2009 | 10:20 AM
  #44
TorqueSteer's Avatar
Our cars are of a "V" configuration = V6. The 6 standing for the amount of cylinder the engine has. Each bank or side of the "V" has 3 cylinders which have their own head with its own valvetrain and a single cam shaft = SOHC. If there were 2 cams on each side then you would have a DOHC.
SOHC= Single Over Head Cam
DOHC= Dual Over Head Cam
http://www.howstuffworks.com/engine.htm
also go to google, hit the images option and punch in V6 engine.
Old Mar 13, 2009 | 10:24 AM
  #45
Maddizm's Avatar
^ DOH! Thanks for clearing that up... I didn't know that we had two heads. But I guess it makes sense now.
  #46
I hate cars's Avatar
In other words, 1 cam per head so there are 2 cams total.
Too bad we can't raise the rev limit, that would probably help to take full advantage of the type S cams.
Old Mar 13, 2009 | 11:05 AM
  #47
Maddizm's Avatar
^ How do you get passed the rev limit? Electronically?
Old Mar 13, 2009 | 02:40 PM
  #48
Teteux's Avatar
Is it worth it to swap those cams? On a stock J32 springs and retainers?
Old Mar 13, 2009 | 02:45 PM
  #49
It's all theoretical until someone tries it.
The generic answer is more duration and lift will increase breathing at higher rpms. You will shift the powerband higher which is why I suggested a higher rev limiter assuming the valvesprings and internals are up to it.
How the TL wil react, we don't know......yet.
Typically cams will compliment an already free flowing intake and exhaust tract. May not do anything on a stock engine. Automatic cars may think twice about this mod as the auto TL already lacks off the line power.
Old Mar 13, 2009 | 03:36 PM
  #50
Teteux's Avatar
Interesting. There's this guy on erformance.net forum with an Accord who's putting TL-S cams in his J30. There's no update its been a month.
The ECU in the TL is that tricky to play with? I mean there's nothing we can do at all with the computer to add 500 RPM? I miss OBD1.
Old Mar 13, 2009 | 07:51 PM
  #51
Sonnick's Avatar
All motor
The TL-s cams will absolutely fit in the TL, as they do in the Accord. One user dyno'd 35whp after raising CR to 11:1 after the TL-s cam install on the auto J33. The J33 is an OEM swap of the MDX crank/pistons.
Old Mar 16, 2009 | 09:10 PM
  #52
Teteux's Avatar
What's the TL-S redline?
Old Mar 16, 2009 | 10:48 PM
  #53
sinfulj32's Avatar
i heard someone on that board has a j30 converted to obd1
Old Mar 17, 2009 | 11:52 AM
  #54
Teteux's Avatar
Hondata released K-PRO for the 04-06 TSX...no TL!
Old Mar 17, 2009 | 11:58 AM
  #55
Teteux's Avatar
That's BS...
http://www.hondata.com/forum/viewtopic.php?t=8645
Old Jun 11, 2009 | 05:15 PM
  #56
04_6SPEEDTL's Avatar
I mod my car in
I'm also planning on doing type s cams in my car, has anyone dyno'd yet to see if there is a gain or am i gonna have to be the first to do it?
Old Jun 11, 2009 | 07:44 PM
  #57
xoulu's Avatar
hmmmmm cant wait for your dyno
Old Jun 11, 2009 | 10:55 PM
  #58
I mod my car in
^ i cant wait either, hope its not a waist of time. Its gonna be a while before i do the cams though
Old Jun 12, 2009 | 03:46 AM
  #59
beachexotic03's Avatar
How about we pass the weak Type-s camshafts. Not knocking them but guys money to hp it's not worth the mod time, blah. Now i have been working really hard to find the anwser to the almightly question? Do the J37 cam fit in our engines anwser is yes. But the timing is an issue. Now thats worth the mod.
Old Jun 12, 2009 | 03:50 AM
  #60
Funk Hondata. Lets bug someone else. How about speed of science?
Old Jun 12, 2009 | 06:09 AM
  #61
RonJonTL757's Avatar
Former Whyner
:piss_on: HONDATA
Old Jun 12, 2009 | 11:09 AM
  #62
ssmtl2nv's Avatar
2009 g37s 6mt
hondata should get off their asses and tune already, wtf
  #63
xoulu's Avatar
about speed of science.... they prob will if they have a loaner car for about a week...
Old Jun 12, 2009 | 04:20 PM
  #64
i would loan my car but i live no so close.
Old Oct 19, 2009 | 03:29 AM
  #65
JoeTL'81's Avatar
6speed Anthracite
has anyone done the Type-S Cam swap and dyno yet?
Old Oct 20, 2009 | 11:11 AM
  #66
Eoanou's Avatar
'10 Hyundai Genesis Coupe
A rep from Hondata had made a thread to gauge interest in a tune for the 3G TL, but none of our members were able to volunteer their car, not mention they were quite rude. It resulted in Hondata losing interest altogether. Although a couple people had said they had gotten a custom tune from Hondata that lowered Vtec engagement and increased redline.
Old Oct 20, 2009 | 01:57 PM
  #67
jdmspec333's Avatar
.43g at 900+fps
i cant believe this thread is still up. anywho, i mentioned this before, for real performance, look into a real aftermarket cam. webcam had a custom grind for j32 tl motors. dont remember the cost, but the turnaround time is about 3-4 weeks, plus you have to send them a set of cams to grind.
Old Oct 20, 2009 | 04:10 PM
  #68
Sonnick's Avatar
All motor
^^ +1. If you really want to see power gains, go aftermarket. Either Webcam or Bisimoto (which is really Webcam, Bisi just makes the custom grinds and gets the work done by WC). Bisi makes some great stuff and is working on cams for the J series. I would expect to see 25-30whp from aftermarket cams. TL-S cams will surely provide an increase, but not near what an aftermarket cam could do. I am looking into some cams and high compression, but that will only be when the pocket allows it
Old Oct 20, 2009 | 07:12 PM
  #69
Opel's Avatar
ive been saying "reground" cams for longer than i care...dont think anyone ever considered it...but make sure you can get a tune once installed... and dont go crazy aggressive or you're gonna hate driving your own car. this would be good for anyone who;s running boost, or will be running boost. I dont know if anyone mentioned this but, if you plan on trying to rev higher, Supertech makes your valve train stuff...I believe Josh from Exr8 posted a thread on it, and can actually get you the stuff you need.
Josh confirm this.
Old Oct 20, 2009 | 07:49 PM
  #70
Former Whyner
Im on the site and I dont see an application for the J series motors. Do you know ball park what this would cost? and do we have to run anything external to have the ECU re-tuned?
Old Oct 20, 2009 | 08:41 PM
  #71
subinf's Avatar
One on the right for me
People were able to volunteer the cars. Mine was there for a day
Old Nov 14, 2009 | 11:13 PM
  #72
Rajca's Avatar
wham bam thank you ma'am
seeing how u can use the rl valves springs on ur guys heads and us cl guys have the same part number as teh rl. someone should try this. dont know if anyone has tried them on the 3rd gen side. but im about to try them on my cl
Originally Posted by divinemotorsports
Hey Everyone,
Great News!!! We have some Supertech Valve Springs and Ti Retainers in stock! Get 'em while their hot off the press...
MSRP: $699.00
SALE PRICE: $599.00 + FREE Shipping to the 48 States!!
Paypal Address: paypal@divinemotorsports.com
Old Nov 15, 2009 | 12:09 AM
  #73
Sonnick's Avatar
All motor
There's nothing for it yet. There is a J series section tho, but nothing is in it I am gonna talk to Bisi and ask, because this car on cams...
Old Nov 15, 2009 | 12:57 AM
  #74
hyperspeed's Avatar
so overall after i read all the comments, it's okay for the tl to install the tls camshaft, but it's better to get aftermarket camshaft if you want to improve more hp in your car. am i right?
Old Nov 15, 2009 | 07:48 AM
  #75
ethenol's Avatar
Mom why is there two?
Use webcam...... I have a set in my TL said it in another thread. They cost 400 a peice but they are worth it. Look them up they have a cam sheet uyou fill out then the ball gets rollin. I'm still usin stock springs and retainers.. No probs. You will not get any traction at all.... I have 275/17 bout a 10 inch wide. BFgoodrich gforce... Still havin probs.... Fun, but better be racin at a roll
Old Nov 15, 2009 | 04:57 PM
  #76
hyperspeed's Avatar
so where do you exactly find the webcam camshaft online? cuz i went to their website (http://www.webcamshafts.com/) i didn't see they list a part for TL!! so i am just wondering!!
Old Nov 15, 2009 | 04:58 PM
  #77
Former Whyner
Me too and my? hasnt been answered yet
Old Nov 16, 2009 | 04:23 PM
  #78
ethenol's Avatar
You arent gonna see a part you have to fill out the engine sheet. It will ask you alot of questions like your bore, stroke all that stuff.... There is alot of questions so find the sheet and just print it out until you have all the questions answered then go back and fill it out.. It's just easier that way
Old Nov 16, 2009 | 04:27 PM
  #79
ethenol's Avatar
Its under the custom cam worksheet. If you have a cam done MAKE sure they give you the grind sheet. They did not send one with a couple of other cams I have had done by them..... I had to call them...... They acted stupid but I got it
Old Nov 16, 2009 | 05:59 PM
  #80
tenzingsherpa's Avatar
J36Twingt28r's,nextgt30r
^^^ how much hp did u gain from the cams??
