Thinking about puttin a button (nos)....
Old Aug 22, 2010 | 04:52 PM
sabioj's Avatar
[IMG]http://tl.acurazine.
Talking Thinking about puttin a button (nos)....
i been looking around the market and seen some things. ive been wanting to put nitrous for some time now, and im moving closer to my mark. i just dont know which one because theirs a few different ones..
Old Aug 22, 2010 | 05:50 PM
sabioj's Avatar
lol damn no1 thinks this could be kool...lol...come on ppl, an extra 50-80 horsepower sounds good to me
Old Aug 22, 2010 | 06:56 PM
VQPower37's Avatar
i think itd be cool, but wouldnt do it to my own car. post a vid after u do it
Old Aug 22, 2010 | 07:37 PM
snake134's Avatar
what do you plan on running? 50 dry shot?
Old Aug 22, 2010 | 07:56 PM
AckTL05's Avatar
Former Sponsor
50-80 HP does sound good, but not for a couple months and then have to rebuild the engine. I would recommend running methanol injection too.
IMO for the kit at $800 then installation, then methanol, then having to refill the tank for $~50 every so many runs its cheaper to buy my sc for 3100 and run safely with a few more mods such as methanol, two step colder spark plugs ($40). 4K to have 80hp constant and save your engine more than NO.
Old Aug 22, 2010 | 07:59 PM
VQPower37's Avatar
im with AckTL on this, i would say just supercharge rather than nos
Old Aug 22, 2010 | 09:07 PM
sabioj's Avatar
hmm sounds good to me.... i was just looking around, i still need some time before i end up buying a sc, but i will definitely have that in mind. thanks for the opinions.
Old Aug 22, 2010 | 09:50 PM
Crestwood1001's Avatar
Nos is not a good option unless you have the time and money to have that shit rebuilt.
Old Aug 23, 2010 | 12:26 AM
NAiL05's Avatar
Why does everyone call it NOS? Thats a friggin company...Its called nitrous. I get irritated as hell when people call it that. Anyway I think it would be nice if you understood how it properly worked. It takes more than a button to get your "power".
Old Aug 23, 2010 | 12:46 AM
AckTL05's Avatar
Former Sponsor
+1, thats why I said NO, nitrous oxide.
Old Aug 23, 2010 | 12:56 AM
Ch33sE1's Avatar
nitrous on a car like this is pointless IMO, if you really want more hp get some fixed upgrades like sc, intake and exhaust which gives the car constant 50-80 hp increase instead of bursts of it.
Old Aug 23, 2010 | 01:03 AM
NAiL05's Avatar
Oh Nitrous will give you power on these motors. By the sound of the op he doesn't know how nitrous itself works. Fast and the furious is a bad example of how nitrous is properly used.
Old Aug 23, 2010 | 08:32 AM
bshevchuk's Avatar
For the same reason people call trimmers weedeaters and adjustable wrenches cresent wreches and personal watercrafts jet skis.
Old Aug 23, 2010 | 08:40 AM
Waltah's Avatar
can the TL even run a wet nitrous system since there's no real tunability? how the hell do you keep from running rich/lean on fuel or rich/lean on n2o?
Old Aug 23, 2010 | 09:36 AM
JMooSeR's Avatar
OP, there are a couple of good, informative threads in the performance mods section. I've been thinking of nitrous or the S/C myself. As the others have said, and what you'll (hopefully) read in the older threads, theres a lot of prep work involved in just readying the engine to safely handle this increase in hp and (spike) in torque!
Old Aug 23, 2010 | 11:39 AM
Yonkers914's Avatar
04Tl
Hey "sabioj" i see ur in YOnkers lol but yea u can run nitruous reliably but just gotta make sure u take the right steps. First off dont use a dry shot! on our cars and i would start off with a 50 shot! Theres more steps u should u take but if u do it right u should be fine. Also get an A/F ratio gauge to see where ur levels r at and a knock monitor if u can. With the car properly tuned u should be fine.
Old Aug 23, 2010 | 12:24 PM
taker777's Avatar
Ran a 100 wet shot on my TL. It's nice. Except when the nos runs out then spending 50$ to refill it a no no :|
Old Aug 23, 2010 | 01:31 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
Find a used zex kit.
A dry kit and it's really easy to install,set up.
All you have to do is change jets.
The box adjusts the fuel.
You are not going to find a easyier way to make big power.
Up to a 75 shot the only thing you will HAVE to do is get one step colder plugs.
100 shot you will need a bigger fuel pump and should use 2 steps colder plugs.
Anything over 100 shot you are going to need some kind of engine management so you can retard the timing ?
But you can add a 75 shot with no issues and it will add about 50-60 hp.
I pieced my first kit together for less than $300.
It may cost 35-50 to fill but,it's well worth it.
Basically no maintaince.
Don't let anyone steer you away from the nitrous.
It is less abusive than a s/c.
S/C is constintly adding boost,nitrous is when you want only.
Also running down the strip a 100 shot tl will smoke a $4,000 s/c one.
Look into a zex dry kit,
It will be the best money you ever spent.
You will smile from ear to ear the first time you spray it.
Guaranteed
Old Aug 23, 2010 | 01:40 PM
I hate cars's Avatar
If you're going to run it with basically no experience, start with a 35hp wet shot. I tried my oooold kit that I used back in the '90s to spool the turbo for one race on my TL and that was it. 35hp feels like more than 35hp since it will bring at least 35lbs of torque with it and it will be at whatever rpm you trigger it at.
I've thought about permanently intalling a 35 shot just because my TL is so incredibly slow. I generally don't like nitrous but as often as I would use it, a bottle would last me a few months so I can live with that.
If you get up around a 100 shot, you need to go to a colder plug, monitor knock, and this is where you need to start getting into higher octane fuel.
Check out some of Inaccurate's threads on nitrous. He's doing it the right way with a supplimental nitrous fuel system (methanol) along wtih many safety items to help the engine live for a long time on a decent sized shot.
Old Aug 23, 2010 | 01:47 PM
Guaranteed
WTF? This is waaaay off.
Even properly tuned, the nitrous is going to be harder on the engine than the blower for several reasons. This is well known by anyone who races or builds engines.
Boost is the most reliable way to add hp except for displacement. The two are not in the same league.
The supercharger only creates boost when you're into the throttle. Normal driving it's just freewheeling.
A dry kit, really? Unbelievable.
Old Aug 23, 2010 | 02:13 PM
I've been running the dry for over a year so,what's way off.
I would never pay what it would cost to buy a charger kit with everything needed,install,and tune.
It would probablly be in the neiborhood of 5-6,000+.
dry kit at most 5-600.
Normal driving the sc just spinning freely ?
and at what rpm's is this spinning freely happening ?
If the sc is not getting it's signal from the tps how can it tell when your driving normal ?
Please explain,I would like to know how it can tell the differance.
With out knowing about the said comptech setup I would think the boost builds at a certain rpm's, say 2500+.
I bet the only time the car would not see boost from the charger would be cruising on the highway or looking for a parking spot.
Old Aug 23, 2010 | 02:18 PM
It builds boost according to throttle. There's a bypass valve that closes when manifold vacuum goes down (opening the throttle more). The supercharger freewheels until you put your foot into it. If it was in boost all the time you would have no control of the throttle.
Old Aug 23, 2010 | 02:33 PM
Now I'm interested in how the setup actually works.
ahh,here come some more knowledge with azine searches.
I drove a friend of mines granprix comp G for
a couple days and it did not seam to be like that.
It seamed like it was boosting at part throttle and not when fully on it.
still rather the nitrous either way.
Nitrous: a box,a bottle,and a couple lines,30 seconds to program.
Super charger : 100 pcs and you kill yourself between install and keeping it tuned.
Old Aug 23, 2010 | 04:14 PM
AMUA6's Avatar
ScoobyZINE
I get my NOS at the Shell right down the road :wink:
Old Aug 23, 2010 | 04:59 PM
tenzingsherpa's Avatar
J36Twingt28r's,nextgt30r
^^ that is the s*it!! i love that
seriously....... its good lol
Old Aug 23, 2010 | 05:14 PM
images's Avatar
05 NBP
so if i just get 75 oz of NOS and put it in my gas i get 70 hp?
Old Aug 23, 2010 | 05:40 PM
snake134's Avatar
yeah but if you mix it in next time you get an oil change you can get up to 115hp+
Old Aug 23, 2010 | 07:04 PM
Waltah's Avatar
contributing
http://www.gixxer.com/forums/showthread.php?t=226570
Old Aug 23, 2010 | 07:30 PM
The easiest way to think of it is the intake manifold is always under some sort of pressure.
At idle and light throttle it's in negative pressure or vacuum. As you open the throttle more the vacuum decreases. Ideally at full throttle you want 0 vacuum in the intake manifold. You'll always pull just a little but it should be very close to 0.
Where the turbo or supercharger comes in is when you hit that 0 vacuum. Another way of putting it is the intake manifold at full throttle is at atmospheric pressure (the same pressure everything around you is at). Forced induction forces more air into the engine creating positive pressure also known as boost..
A turbo or supercharger is nothing more than a glorified air compressor. Instead of the engine having to suck the air in, the supercharger forces it in.
This positive pressure is a natural extension of an engine's operating range. There is nothing harmful about it. Instead of 0 psi being full throttle, you'll hit 0 very early on and whatever you have the boost limited to will be your new full throttle pressure. It now has more range. Instead of -18 to 0psi you now have -18 to 5psi or whatever it's set to.
With FI, you will hit 0 vacuum before you hit full throttle and transition into boost. A very lively turbo setup or roots blower can go to 0 vacuum and start making pressure by 1,500rpm.
Like I said, FI helps the engine breathe and it's linear. The more throttle you give it the more boost and power you make. Most people could not tell a turbo car from NA if you did not know already.
Nitrous on the other hand is instant. This is bad for several reasons.
First, you have no time to back out of the throttle should something happen like the fuel solenoid not opening. Damage happens in miliseconds on nitrous.
Second, the instant hit is harder on internals.
Third, since it's a chemical oxygenator it's been known to cause more heat in pistons and the combustion chamber as a whole which leads to a host of other issues.
Racing... It's on or off. If you're making any serious power you have to know when to inject it. There's no such thing as backing out of the throttle when you're on it.
It is a chemical. You're injecting something that was never intended to be injected into the engine. For fear of over simplifying it's "liquid air". Now what do you think is easier on the engine:
Something that increases natural airflow linearly with throttle or something that injects "liquid oxygen" all at once?
I'm not here to argue this point, it's a well known and proven fact that nitrous is harder on parts period.
And a dry shot... Do you monitor knock, AF, or read your plugs? If not, you're driving a timebomb. Believe me, your fun will be limited. There are many safeguards out there to make it more reliable but something tells me you're not using any of them.
Old Aug 23, 2010 | 07:39 PM
images's Avatar
05 NBP
I think IHC just told you everything you need to know.
I just installed this in my car
you wont regret it, instant power
Old Aug 23, 2010 | 10:24 PM
TL Luver's Avatar
2006 6spd
just get a sc 1st and then get nitrous afterward!!! Duhhhhhhh!!!
Old Aug 23, 2010 | 10:32 PM
It's funny now but in the old days we used a turbo+ nitrous. I'm so happy for advances in turbo technology so nitrous is not necessary anymore.
Off topic but I was at a friend's shop and watched a 425" C6 Vette put down 470rwhp on motor and 808rwhp on the bottle. Only had the 200 pill but nitrous is funny that way. It had it's own 2 gallon race gas fuel cell in the front just for nitrous. It was fun to watch but just not my thing.
Old Aug 24, 2010 | 11:18 AM
I love when people try to argue with I hate cars. The man knows his shit, dont argue haha
Old Aug 24, 2010 | 11:34 AM
images's Avatar
05 NBP
you gotta set up your sc turbo and nos so the nos goes in the sc which spools the turbo
don't forget the button though or it wont work
Old Aug 24, 2010 | 11:57 AM
04accordcpe's Avatar
347hp/300tq @ 4psi
nos = ghey
Old Aug 24, 2010 | 12:27 PM
JackSampson's Avatar
I like calling it NOS because that is what they called it in The Fast and Furious and that was the BEST MOVIE OF ALL TIME!!! If you gonna run NOS go big or go home. 150 shot BiAtCh!!!
Old Aug 24, 2010 | 12:48 PM
I have friends that run 400 shots. One in particular in his junkyard 5.0 Mustang. He ran 3 stages. A 50 shot from the start, an additional 100shot when he hits second gear and 150 additional at the top of second. 300hp on a stock 5.0 with only headers and exhaust. It went 10.90s for a month at a time. Since he owned a junkyard, engines were practcally free. This guy used to have the first stage triggered with the throttle, second stage near the shifter, and 3rd stage with a button that he held in his mouth and bit lol. This was one of the few local guys I did not race for money because he didn't care if his stuff only held together for a couple runs.
Old Aug 24, 2010 | 03:45 PM
I actually have 2 stages installed .
I have only used one.
I plan on making one to get it off the line.
And 1 after the wheels wont spin.
Till ecu,injectors,and lower end internals it will probally be
55 first shot then a addional 75.
If I had everything needed ,
I would want 75 first shot 125 2nd.
Both boxes
First injection spot
2nd injection spot
Bottle
Old Aug 24, 2010 | 03:56 PM
images's Avatar
05 NBP
you.
need.
to.
stop.
typing.
like.
this.
is that box big enough?
Old Aug 24, 2010 | 04:47 PM
phee's Avatar
I got the Shifts
rich man. give up. and your setup looks like shit.
i tried explaining that running a dry shot was a bad idea in another thread and you still dont get it. continue riding around with that untuned and enjoy your future burn valve (like another member with a 2g before you)
also, 3g guys should read some of this guys threads
