Is there a need to replace headers?
ive heard you can get up to 30 hp with headers on a g2 tl but my question is would i get the same results if i got different headers on my 05?
you absolutely would get the same results on your 05.................if you had the ability to run headers!
While they don't make traditional "headers" for the 3g TL, you can still get the equivalent which are referred to as PCDs or, Pre-Cat Deletes. The difference with our cars is that instead of having individual ports on our heads for each cylinder, we have a single, large collector cast into the head. That's where either the stock pre-cats, or a set of PCDs bolt up. I wouldn't expect to see 30hp from PCDs, but I believe people have posted results which are in the range of 15-20.
InstinctGT (09-30-2012)
I believe that Richie's are the most popular. if you go to: r_v_6-p.com (remove all of the underscores '_') you should be able to find what you're looking for. I'd stay away from the earlier versions (v1 particularly) as they had problems with the pipes cracking, but the V3 design looks to be significantly improved.
One thing to keep in mind that I didn't explicitly mention above is that they do exactly what the name implies. They remove the pre-cats from your car. The pre-cats help with the exhaust smell and also with quieting down the exhaust tone. Some guys have mentioned that they've picked up a rasp with PCDs. The 3G TL does have 3 cats though, so one will still remain in tact.
If you live in a smog controlled state, you may not be able to pass inspection unless you swap in your cats each time before you go. I cannot speak to this first hand though. There are probably a few dozen posts on here regarding PCDs. Just do some searching before you pull the trigger and I'm sure you'll find all the answers you're looking for.
Now with that in mind, ive been looking for some threads that go into depth about the emissions, and none of them are really state specific. if anyone in CT has done this mod and passed could you let us know if you replaced your third cat with a high flow cat or something.
yeah sorry about that, i found some threads after i posted this. Ill do some research before starting threads.
I have hi-flow cats at all 3 locations. I have passed the California sniffer but not by much. I think I could loose the 3rd cat but it would be very close. If the tech is on his game they will not pass visual inspection.
well after some searching i found that CT doesnt have a sniffer on newer cars, but they check for codes and theres a visual inspection. So im hoping for a lazy inspector and maybe get through with 1 high flow third cat.
The pre-cats are clearly visible from the top (under the hood) so that won't help you there. Nice and shiny tubes running from the heads won't help your case.
TLove It! (10-01-2012)
The other thing that the OP could do is consider running Richie's HFPCs (or, high flow pre-cats). They look more similar to the stock cats, but likely flow MUCH better. I don't know what the cell count is on the stock cats, but I can tell you from experience that it doesn't take much for mods to exceed their capacity.
The other thing you could do, either with the PCDs or the HFPCs, is to weld tabs on to them which would allow you to mount the stock heat shields back up to them. It's probably enough to fool the average guy doing the inspections.
07 NBP 5A/T UA6 NAVI
Alright, so from whats been said, Im probably going to do PCDs with a high flow 3rd cat. i think that i will be able to pass emissions with that setup. I also think that i will try to get the original heat shields on the first cats, just in case i get an inspector that actually cares.
cycdaniel
12-17-2019 10:58 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
