Test Pipe vs. Gutted Cat
I could have swore there was a thread about how a test pipe in place of the 3rd cat could lower torque. Well I can't find it now. Can anybody confirm this? Also would I gain any torque if I replaced the test pipe with my gutted
3rd cat?
3rd cat?
Especially considering how expensive they are
When I worked on exhausts I actually loved people like this - they would come in and tell me they wanted to gut the cat (couldn't do). But I would be more than happy to make them a 'test pipe' for tuning purposes. I'd either sell the OEM cat for a shit ton of money (relative to the price of a new one) or salvage it for 40-60 dollars. Such a waste to simply bang out the insides.
but by the sounds of it he already has the gutted 3rd cat. but like the others, destroying something that is so expensive to gain a few ponies is so not worth it. and then if and when you fail inspection and you have to replace it, you are now double boned!
A lot of people in the Subaru community used to gut the cats in their uppipes simply because it was free to do it. It makes an awful mess, the dust is extremely hazardous to breathe in and it's a pain in the ass to do. If you do it right though it was just as good as the catless versions of the uppipes you'd find on the aftermarket at 0 cost.
Ok to clarify I have the RV-6 test pipe installed. I removed the 3rd cat which is still in perfect shape. So there is no advantage to gutting the 3rd cat? It feels like I lost low end torque when I put the test pipe in. Maybe I'll just put the cat back in an see how it feels.
stupid to guy any stock cat. there is absolutely no need for it, since their are PCD's and race/test pipes available.
also, the stock 3rd cat bottlenecks anyways, 2 1/2 inlet, 1 7/8 so it can match the stock exhaust piping.
Gutting the cat has a couple advantages.
It's free.
It's less likely to cause raspiness.
It will give the same power gains as a test pipe.
It will pass a visual inspection.
Like I've mentioned a hundred times before, I had a friend smog my car with the 3rd cat removed before I gutted it to make sure it would pass CA emissions. Since it passes, there is no need to ever run it again so there is no harm in destroying it.
The last thing you want is to get caught with a straight pipe in a communist state like CA.
Would I do it again? Probably not just because I felt no difference. My car is also bone stock power wise. Someone with precat deletes and full exhaust along with other engine mods might feel a difference. Mine was actually done to hopefully increase fuel economy since I was commuting a lot. It would also be a good idea to bore out the inlet and exit if you were serious about power. But the media is the largest restriction by a long shot. A 300 cell cat is almost high flow territory in iteslf so again, unless you have other mods you're not going to gain much by gutting it or running a test pipe.
It's free.
I forgot, no way will removing the stock 3rd cat cause a loss in low end torque. It's hard to actually lose low end torque no matter how low the back pressure goes and the 3rd cat just doesn't cause much of a restriction in the first place.
I remember a few members saying that they lost a bit of low end torque when they took off the third cats... They also had the Pre-cat Deletes, J-Pipe and other exhaust mods, maybe a bit to free-flowing?
I remember a thread with a dyno about precat deletes increasing top end & dropping low end.. I could be mistaken.
MrHeeltoe
20
02-23-2023 02:54 PM
08_UA7_Gr33k
02-11-2016 03:17 PM
MrHeeltoe
09-29-2015 11:43 PM
MrHeeltoe
09-28-2015 06:43 PM
