Test pipe problems?
Old Nov 19, 2013 | 01:37 PM
troy_279's Avatar
Test pipe problems?
Hi all. Recently i installed a test pipe on my 07 TL (replace third cat) on my otherwise stock car. I was hoping for a little mpg gain but started to see problems. I have a bluetooth adaptor plugged into the OBD port to monitor all the systems of the car. It is very similar to a scangauge. as others have noted when you let off the gas and coast your car shuts the fuel off completely which i had noticed as well. since i installed the test pipe it no longer shuts the fuel off when coasting. i was wondering if the test pipe would cause this or something else happened at the same time to the car as coincidence. i cant put the 3rd cat back on as i had the test pipe welded in. anyone else notice this?
thanks
Old Nov 19, 2013 | 01:46 PM
since there are no sensors on the third cat, its hard to believe this.
since, you cant put the third cat back on, you cant test your theory....
Old Nov 19, 2013 | 01:56 PM
troy_279's Avatar
i find it hard to believe as well, just thought someone else with a scangauge with a test pipe could check their car
Old Nov 19, 2013 | 02:03 PM
in for test's.
Old Nov 19, 2013 | 03:54 PM
KN_TL's Avatar
Does your scan tool have a logging feature? If it does, record it and post it up for all to see.
Old Nov 20, 2013 | 08:38 AM
troy_279's Avatar
I'll check and see, never thought of that
Old Nov 20, 2013 | 12:24 PM
troy_279's Avatar
i couldnt find any sort of logging feature
Old Nov 20, 2013 | 12:38 PM
Nick216's Avatar
The Boss
welded testpipe? better hope you don't fail emissions lol.
Old Nov 20, 2013 | 02:04 PM
troy_279's Avatar
i'm up here in Canada so we don't have emissions tests and its a few years away so I wasnt too worried about that!
Old Dec 1, 2013 | 01:52 PM
4drviper's Avatar
I don't have scangauge but I use garmin mechanic to monitor realtime MPG/fuel consumption.
it never cuts fuel, according to the computer but I always get more MPG than what OBD2 calculates. so I just think it does cut fuel.. but somehow it's not being read by OBD2 port like..
mada51589
Jan 9, 2025 04:40 PM
acurajj
Feb 14, 2016 02:28 PM
IIDXholic
Oct 8, 2015 07:53 AM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
