TB Coolant Bypass Mod...anyone do this?
I did it last year. The TB stays cool to the touch now where before it was too hot to touch. No problems in the winter.
Originally Posted by t0talacuratl
Isn't this the power adder option on the AEM CAI?
I want to know how to do this, Im gonna try taking a look.
The Kinetics of Bleu
Originally Posted by evanj5
No, thats switching the sensor.
AZ Community Team
Received 7,771 Likes
Registered VTEC junkie
I'v done this for about a month to see how it goes. The engine seems to run richer(fuel). My gas mileage decreased so I put it back to normal. Not worth it for me..
9632tl (01-06-2012)
Originally Posted by I hate cars
That's just about impossible. On one hand people on here claim a couple mpg bump with a CAI but with a cooler TB it causes a decrease in mileage. It will have very little effect on the incoming air charge. It's one of those "why not it's free" mods and every little bit helps but you won't feel a difference in power or fuel economy.
Originally Posted by flydog
Actually you are both wrong. Cold air is denser so the engine would run leaner with the coolant bypass disconnected. However, the mass airflow sensor compensates for temperature and density and will richen the mixture automatically. That means it will run at exactly the same ratio as before (not leaner or richer) but it will use slightly more fuel. Probably not enough to be noticeable.
The 02 sensor will keep things in check if the calculations are off a little. Doesn't really matter because we're talking a very, very small temp reduction. If it weren't free, I wouldn't do it.
ive done this mod on every car ive had: 00 civic ex, 92 civic si w/ integra ls swap, 02 civic ex, and my last, 05 rsx-s.
it does not give you more hp, it only keeps your TB cooler so that you keep the hp you have with a cool engine, will stay longer as your engine and underhood ambient temp go up.
for example, we all know when we first go out driving our cars feel fast, then as it gets hotter(the engine), it doesnt feel as fast.
this mod will keep your engine running almost as it was in the first 30 min of driving.
it also helps to paint your CAI with high-temp paint, it will keep the inside of the pipe barely a little cooler, but that mod, although it works, its a little useless and the paint can get all scratched up.
The sensor that you have the option of swapping with the CAI will add more fuel and advance timing, not make you run leaner.
That would be great if the TL used a mass air meter, but it's a speed density system. You would still be wrong on a mass air car because the TB is after the meter.
They both do the same thing. Adjust air/fuel ratio depending on temperature and/or density.
When installing my AEM intake, I just did the mod anyways, since I had to reroute the coolant hoses.
I noticed that the TB is cool after driving on the freeway...anyone who didn't bypass it notice that their TB is hot after the freeway?
Yeah my TB no longer gets hot anymore, cool to the touch. The p2R spacer really helps this mod work perfectly.
We need more mods like this
Im thinking colder spark plugs for me next, what do those run?
I have also heard making the coolant a 40/60 mixture versus a 50/50 will make the engine colder as well.
OH OH and I also read that if we can figure out a way to trick the computer to think that the EGR is not working then the ecu will add more gas and pull back timing which I believe would give more power on our cars (well especially mine cause it pings) just dont know what kinda of CEL it would throw as well
ummmmm....
Does the engine cover increase engine temps?, what about all the other pieces of plastic in the engine bay, would removing them help keep temps down???
I am definatly going to get synthetic on my next oil change as this should reduce engine friction and temps,
Any other ideas or comments ?!?!?!?!?!? little things like this are fun to tinker with
ummmmm....
Originally Posted by Tripnbeats
lol evan, havin a bad day are we?
i did mine today! lol forgot to plug the little sensor on the TB back on the top and almost shit a brick when i thought my car was gonna blow up on me haha but it seems to run better on the butt dyno.
Summer must be getting near.... I have been receiving several PM asking for advise for doing the coolant bypass. Here are a few photos of how I did mine. Hope it helps those that are looking for a HOW-TO. Cheers
Turd Polisher
What do these hoses even do? Why aren't they necessary?
Do I need to buy a whole new tube just for this mod, or use the ones off my car?
Originally Posted by TylerT
http://pic80.picturetrail.com/VOL836.../315762513.jpg
And you should not have to put anything I just reused the hoses that come with the car. Its super easy and there is a picture above to show you how it goes.
D
.:KCCO:.
i just did this mod a couple days ago. thanks for posting the pics to make me feel more comfrotable with it. wasnt sure if i rerouted the hoses right.
question, doesnt this mod negate the need for the TB spacer? since the heat experienced comes from the coolant warming up the TB, this mod has the TB not getting hot.
i know the engine gets hot too, and the TB spacer makes it so that the heat doesnt transfer from the engine. but if the TB is staying cool when moving and the TB is between the engine and the intake, then it doesnt matter that much if at all right?
Turd Polisher
Just did the mod, the car definitely doesn't feel like it gets heat soaked after driving ... I love it.
My only suggestion is, have a towel handy in case any antifreeze leaks out.
I think this actually makes the TB spacer even better, I mean now the TB spacer stays super cool and I believe that increasing the amount of volume that is before the IM is another reason the TB spacer is put on. And without the TB spacer wouldnt the TB still get kinda hot from the IM?
.:KCCO:.
i think im losing a bit of gas mileage. i havent changed the way i drive. can someone who knows whats going on chime in on this?
you know when you first start the car, the engine revs a bit higher until it warms up and that uses a bit more gas... is it possible that sensor is in the throttle body? does that mean at idle, it is using more gas thinking it is not warm enough?
The only thing that could cause a high idle would be if you accidentally knocked a vacuum line off or left a sensor unplugged.
