Supercharger reliability
good luck to all, but i actually think that seafoam killed my motor. Acura is replacing the head, cylinders, injectors, gaskets, plugs and basically anything else in there that was fucked up. Basically a rebuild and I believe the car will be more reliable without the blower. Any imput??? I dont know much about motors, but does the head involve pistons and rods??? becuase if those didnt fail, then the blower is not the blame, just a faulty motor. I mentioned that i used to get a flashing cel at wot, when I was bone stock, which worsened with the extra mods...
Your motor is damaged for sure, and possibly your heads. There is no such a thing as a 'faulty' motor. You OR something external did something to damage your motor. But with all that damage you'd get more than just a flashing CEL at wot.
weird, Im gonna pull the blower off and justreplace that bady with an aem v2, it has been great and now it is time for Bforbrian to enjoy it.. Ive had numerous problems b4 the blower and think it finally bit the dust. I will be picking it up in a week.
Ok...what prep work do I need to do before getting the comptech. I mean as far as parts. This is the first time I heard about the preinstall checklist test. I've heard of getting a Meth kit, I'm getting an exhaust. I have the Jpipe and test pipe (thinking about precats). I guess I"ll hold off on CAI and make a custom one. Do I really need gauges? Is there anything else I should amass before getting the blower itself? Oh I have a UR stock size pulley too.
Former Sponsor
Former Sponsor
I think we should be clear here though and clarify that it's not b/c of the supercharger kit that your motor blew. The CT kit is complete and there is nothing wrong with the kits.
What could have caused the motor the blow up? I am just curious because as we speak I am thinking of buying S/C
Former Sponsor
So, just a bad spark plug can cause the motor to blow? WOW, my bro has the A4 and we installed big turbo and all of his spark plugs went bad but the motor did not blow up.
Former Sponsor
Well he mentioned a bad injector; a bad spark plug seems unlikely. But if you are going full boost and the car is having issues and you have a bad injector yes you might have an issue in that cylinder. But once again, that's not a supercharger issue.
Which injectors are we talking about. Is it the fuel injectors?
I would recommend it. I saw that radiator project...looked VERY nice.
The belt issue only seems to happen when using the HBP(high boost pulley) so my belt is fine. I would say the question should be more about the money and how much you like the TL. I love every thing about this car so 10k worth of performance parts was worth it to me. The Comptech Supercharger is the ultimate mod for the TL, once you get it you will want/need every other part for the car. All a sudden $1000 mods are a once a month thing and you are stashing parts to hide them from your wife.[/QUOTE]
HAHAHA I just read that and made me giggle, sounds like meeh! I think my wife plays naive but then I can't say anything if she purchase stupid purses like that....I just sighing....with a smirk.
Any of you that have the supercharger, did you have to change the fuel injectors?
I know the kit comes with spark plugs but besides that did you have to change the fuel injectors or you let the factory ones in?
Former Sponsor
Hello All:
I had the Comptech SC installed March 12, 2007 by a Acura dealer in San Diego. I later went to the TSX-s injectors and the HBP.
I was also able to get a Hondata reflash. I am still using the original belt put on with the SC installation. NO wear on the belt.
I just turned 60, so I do not race every day, but when I need the power it is there.
The Comptech SC is very reliable and will provide a good performance upgrade and last a long time.
Proper installation is the key.
Enjoy the power.
Tim
Enjoy the power.
Tim
yea the checklist id say do a compression test....get ur plugs checked but those are changed out from comptech, so no issues come of it....check the injectors n make sure they are clean, if not change them too.... make sure the coil packs are ok too... make sure u have no vacuum leaks ur head gaskets are ok etc etc.... these are just typical things a good mechanic would check n make sure is ok before doing the install. if theres an issue i hope he brings it up and you have it cheanged out..... ive seen blowers installed where people have valve issues where they need to be retightened and a week later the motor crapped out because valves werent tightened down as if the motor was new.
It won't hurt it as bad NA but with the blower a bad tune will kill a motor.
The blower is not the culprit with these blown engines, it's the lack of proper engine management and octane. I will bet that no one running methanol will have a failure with the blower even with the HBP.
Hello All:
Enjoy the power.
Tim
Enjoy the power.
Tim
Also is there any benefit from usig the TSX or RSX injectors?
A bad injector will cause failure. Ask me how I know lol.
You could pull them and take them to a fuel injector shop (most diesel stores do it) and have them flowed.
If we had conventional headers you could compare temperatures across the headers to find a bad one.
You could go old school and read the plugs.
You can scan it and see if your fuel trim is out of whack.
Depends. If it's got varnish causing the problems, seafoam can possibly help. Each injector has a little screen inside that can get plugged and injector cleaners usually won't help this. They can also go bad or get lazy.
Have you looked into the RSX type S injectors as someone here recommended as a replacement.
im am going to eventually switch, what year rsx s is okay??? BTW can u give me the part # to the denso plugs that we use for the s/c, I need to pick up 6 of them so that acura dont throw in the oem ones with the boost. Thanks.
