Straight pipe with no muffler with supercharger
B A N N E D
So we all know that for NA cars we need back pressure so the exhaust pipe cannot be too big.
However on FI cars, do we need back pressure? Would we gain performance if we have a high flow exhaust? for example, the exhaust manifold would go to a straight 3" pipe with no cats or muffler.
Since we have two exhaust manifold, would there be gain if we have two seperate pipe, one going to each exhaust manifold? for example, true dual straight pipe exhaust with no cats or muffler.
I know that with a exhaust like that it would be LOUD AS HELL, but this is for racing and track only.
Import and Domestic owner
One on the right for me
Will be loud as hell, sound like shit, and very hard to run true duals due to lack of space under the car. Could be done but would take some time and not worth the effort.
Ryan Christopher
With the low amount of pressure with the CT setup, I would just use the Procats and some 3" tubing after the J-pipe. JMO
B A N N E D
So do you think the stock J pipe is good enough and would actually be better since we are running low boost?
If that's the case, I would just run 3" pipe from the J pipe and exit in the back with no cats or muffler, or maybe a straight through muffler.
Ryan Christopher
Be sure to dyno the car before and then right after with the new exhaust, this will let you know if what you did is helping. I would try to find a flange to work with, this way you are not chopping your stock exhaust to get it. Good luck!
Jason
Originally Posted by AcuraDriver2006
running a straight pipe, you know how loud the car will be? I have a clip of a cobra running 4'' straight pipe...... you should hear it. hahahaha crazy
B A N N E D
That is actually my next step, to have pulleys made to boost a little more and hopfully will also lean out the overly rich AF ratio under boost.
Originally Posted by TLdriver022
A V8 with straight pipes will be alot louder then a V6 with straight pipes
thats not saying much though. i had a 98 tt supra and for fun (bored) took off the mufflers and ran straight pipe. loud as shit, mufflers went back on
Joe Avesyan
09-29-2015 03:57 PM
johnpancakes014
09-27-2015 12:58 PM
