Stainless Steel bolts for OEM 3rd Cat
I am in process of putting my OEM Jpipe and 3rd cat back on. I want to put some stainless steel bolts on it this time because i want to prevent them from rusting on. I am not too sure what type and size bolts I need. Any info would be greatly appreciated!
The 3rd cat has studs pressed into the flanges. That means there are only nuts that you can repalce w/ stainless. There are no threaded holes for "bolts".
![](https://www.acurapartswarehouse.com/diagrams/large/exhaust-pipe-muffler-226508.png)
The front & rear cat use threaded studs that screw into the flanges. The studs are 10x24mm, but I'm not sure of the thread pitch (maybe 1.25mm). You will need to subtract the bolt head length from the 24mm if you plan on making the switch. Typically these studs are very difficult to remove, which is why OEM doesn't use bolts. The nuts are much more likely to come off over the years vs a bolt due to the extreme heat cycling in this area. Who knows....it may just work. But you won't know till you try and remove them years later.
![](https://www.acurapartswarehouse.com/diagrams/small/converter-226636.png)
I'm going to do the same thing.
I was just going to go to the hardware store and use 10mm SS bolts/nuts and a liberal amount of copper anti-seize.
I guess KN is saying that the lower grade bolts will gall because of the heat cycling that occurs in the exhaust. I'll probably use the higher grade 8.8, 9.8, or 10.9 bolts. I'll have to find out what my local store sells.
Former Sponsor
We used to include stainless hardware with our products. They would seize and strip easily. The worst part was that if you didn't seize them on they would start to self loosen from all the heating and cooling cycles.
At my work we use a lot of fasteners for pressure products. ASTM/SAE type. Mostly A-194 B7 which is an alloy steel with high tensile strength, but will surface corrode. For 316 SST, there is multiple class. Class II B8M 316 SST has a higher tensile strength than class I B8M 316 SST. Fastenal is good source for specific fasteners.
ExcelerateRep
Sponsored Sales & Group Buys
01-06-2016 09:59 AM
ExcelerateRep
12-11-2015 12:58 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
