Some photos of air intake resonator chamber
Old 02-26-2012, 08:17 PM
Proud owner of a...
serbj's Avatar
Cool Some photos of air intake resonator chamber, for those interested in DIY air intake
I investigated the air intake resonator chamber of 04-06 Acura TL today, in order to figure out how to actually make a cold air intake system myself, according to the no photo (therefore worthless)thread:
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/diy-cai-569702/
This thread's OP, JDM5lugHatch's idea is:
And you can find the part numbers and illustration at OEM Acura Parts:
http://www.oemacuraparts.com/find-pa...ER%20(-'06)
I remove the front bumper, and here is the resonator chamber:
I don't quite know what this auxiliary pipe is for. I thought it could be for wires to run through it, but there is no wires in it. Both ends of it are open. Here is another picture:
And here is how it looks when I removed it:
Here is a view of entire resonator chamber:
There are at least 3 visible screws holding it in place. This is the first one on the left. It is a 10mm screw:
Closer:
There is another one holding it on the right:
And the last one appears to be very difficult to reach. This photo is taken when looking downwards next to the battery. In this photo, you can see the battery mount on the top of it, and the pipe is #1 intake pipe (air intake tube C: 17245-RDA-A00).
Thoughts after investigation:
1. A 10mm box end wrench won't work, because there is plastic trim around the screw. You need a screw driver with 10mm box end head to unscrew the screws;
2. You need to find a way to unscrew the 3rd screw under the battery box;
3. Cutting of the resonator box would be challenging if you don't have automatic tools. I try to hand cut it, but the plastic is very, very solid.
The following 2 users liked this post by serbj:
2doped (02-29-2012), TLTodor (07-06-2012)
Old 02-26-2012, 08:31 PM
Proud owner of a...
serbj's Avatar
In case if the photos are down:
Old 02-26-2012, 11:45 PM
goodoldayz's Avatar
you should add this to the other thread you linked to in order to syphon all the conversation into one spot. just my two cents. but subscribed anyway
Old 02-27-2012, 12:08 AM
AZ Community Team
Bearcat94's Avatar
Received 7,771 Likes on 4,342 Posts
First half of this vid shows all the bolts/connections to remove the stock tubing:
B-001: DIY VIDEO: Uninstalling OEM Intake & Installing Cold Air Intake
https://acurazine.com/forums/showthread.php?t=169110
More stuff here: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/
Old 02-27-2012, 01:46 AM
Proud owner of a...
serbj's Avatar
I was worried I will be punished if I reply to an old post.
Old 02-27-2012, 05:07 AM
goodoldayz's Avatar
dont worry, i resurrected more dead threads than Jesus !
Old 02-29-2012, 01:30 AM
2doped's Avatar
Thank you for the pictures! Been looking through old dead threads looking for detailed pictures on the removal of the stock resonator with no luck. So once it's out do you connect the new gap with a tube?
serbj (02-29-2012)
Old 02-29-2012, 07:03 PM
Proud owner of a...
serbj's Avatar
Thumbs up
On Monday I finally got this DIY cold air intake system done. Kenyon has my thanks.
I came out that it is actually a little bit too tight for Pipe#1 to fit Pipe#2, so you have to take a heat gun to soften the end of Pipe#1 first.
Besides that, everything is perfect. This DIY is so "stock" that you will think the chief designer's must have deliberately designed it; and it is so efficient, comparable confidently to the AEM one.
Old 02-29-2012, 07:19 PM
Proud owner of a...
serbj's Avatar
I don't have a subscription of a stable image hosting service. Therefore I uploaded a backup group of these photos to Photobucket.
The following 3 users liked this post by serbj:
2doped (02-29-2012), goodoldayz (03-01-2012), TLTodor (07-06-2012)
Old 03-01-2012, 12:39 AM
A SiQ TL's Avatar
Old 03-02-2012, 03:33 PM
I'm The Nickel City Kid.
ACON's Avatar
Looks good! This was helpful with my removal. Thanks!!
Old 03-02-2012, 04:19 PM
corcraft's Avatar
I love this!!! might just have to sell my aem
Old 03-05-2012, 10:00 PM
jungy4's Avatar
Could someone post some sound clips? I have been thinking about doing this for a while.
JD TL-S (03-09-2012)
Old 03-05-2012, 11:20 PM
rhafikjaan's Avatar
where did you get that first pipe?
Old 03-05-2012, 11:43 PM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
I also wonder how it sounds compared to a CAI.
Old 03-06-2012, 07:12 AM
Received 16,267 Likes on 11,974 Posts
Reading does wonders
Old 03-09-2012, 01:41 PM
JD TL-S's Avatar
Thanks.
But isnt the AEM V2 tuned as an intake ?
I dont think its all about cold air. The AEM V2 is specifically designed for proper torque at certain RPM's.
Not sure, but I have read this on here somewhere.
Nice Thread Something to think about thats basically free compared to the AEM V2
Old 04-25-2012, 09:12 PM
07 WDP TL-$
J35A8's Avatar
Red face
What ^^^^^ said.
Where did you find the down pipes
Old 04-25-2012, 09:19 PM
JW64's Avatar
Could you post a video of the new sound? Seems like a nice weekend DIY job.
Old 04-25-2012, 09:30 PM
Originally Posted by J35A8
What ^^^^^ said.
Old 04-25-2012, 09:44 PM
07 WDP TL-$
J35A8's Avatar
I did something similar but i didnt use rivits to atach the piping. It looked a lil different thats why i asked. Needless to say, ill be adding rivits
Old 04-25-2012, 10:53 PM
JD TL-S's Avatar
+1 Please.
Great Idea
JW64 (04-26-2012)
Old 04-26-2012, 07:22 AM
veggiemonster's Avatar
I knew I should have taken pictures of what I did, but now its all destroyed.
I didn't heat it, I just forced the tubes to snap back in, and it looked longer than what you have.
On the splash guard which is in one of pics you showed, I cut a hole, and it was about flush. The intake was actually really loud outside that way
Old 06-30-2012, 08:34 PM
Bruce Banner's Avatar
I was just kicking around the same idea then found this thread.
Any MPG gains?
Does anyone know where that "unknown" pipe goes to?
Old 06-30-2012, 09:14 PM
BukvaMan's Avatar
Any MPG gains?
the unknown pipe as you call it, in my opinion directs air upward where it gets collected on top of the intake tube... pretty much when driving it pushes colder air up to the intake, so instead of sucking in hot air you get fresh air up there. I dont think you guys are gaining anything but sound. The nice sound from an intake comes from the CONE FILTER but with this option it probably has a drone to it and its just louder in general.
Old 06-30-2012, 09:19 PM
I just saw the diagram online, you're right. It looks like it leads up the the grill area where fresh air is brought it. The OEM intake is already a CAI. It just takes a longer route and has a resonator in the way.
That spot where all the CAI's are putting the cone filter, it makes the path shorter, but the OEM design seems to be where the real cold air is at.
Old 07-01-2012, 12:27 AM
BukvaMan's Avatar
I have my K&N cold air intake in my closet . By going back to stock i gained back low end torque which is much more pleasant when driving around town in a car that doesnt have much low end torque to beginwith. Im sure my engine will be healthier too and i dont have to worry about hydrolocking any longer... The only thing i miss is the sound from it ...
Old 07-01-2012, 09:56 AM
Gain any MPG using it?
Old 07-01-2012, 02:22 PM
rossv1's Avatar
So where are these videos? haha
Old 04-25-2013, 01:22 PM
8th Gear
Travis McCune's Avatar
Back from the dead... isn't anyone worried about sucking debris up in the pipe without a filter?
Old 04-25-2013, 01:26 PM
^the stock filter is STILL IN PLACE.
you would be a fool to run it without
Look at the pictures again, travie mccoy, no one touched the stock filter.
Old 04-25-2013, 01:32 PM
zachlone's Avatar
Travis this mod is only deleting the intake resonator not the OEM airbox that houses the air filter.
The following 2 users liked this post by zachlone:
rossv1 (04-25-2013), Undying Dreams (04-25-2013)
Old 04-26-2013, 07:26 AM
8th Gear
That makes since now. I looked at a bunch of these mods and a lot of them were replacing with an aftermarket K&N filter or something of that sort. That's what through me off on this one.
Old 04-27-2014, 06:49 PM
Sledneck's Avatar
It is not dangerous for the engine to suck snow with this set up?? Water probably not because it is heavy but snow is really light so I think it will probably reach the filter!?
Old 04-27-2014, 08:41 PM
vietxquangstah's Avatar
There's a giant bumper blocking the inlet. There's also a plastic plate underneath the car that will prevent most things from going up into the inlet tube.
Should any snow make its way into the tube, the engine air filter will just do it's job and absorb it.
I really don't see snow being a problem unless your using your car as a snow plow.
Old 04-27-2014, 08:51 PM
KCCO
MarcoNorthPolo's Avatar
Hey, that's happened. This winter. lol
Old 04-27-2014, 08:57 PM
Sledneck's Avatar
Yes but the snow can enter by the trap in the corner of the bumper (don't know how you call that in English?) in a snow storm for exemple. I live in quebec and we have a lot of snow believe me! But yes it is true that the filter will block the majority of the snow.
Old 05-04-2014, 01:05 PM
6th Gear
Lkracerpdx's Avatar
Anyone know if the intake resonator delete gains mpgs? is it as loud as an aem v2 cold air intake?
Old 05-04-2014, 01:21 PM
The Boss
Nick216's Avatar
Doesnt gain mpg. Its louder then stock but not as loud as the aem v2
Old 05-05-2016, 08:47 AM
LeVeL's Avatar
Resurrecting for a few questions: I'm guessing this mod wouldn't affect resale value, despite being irreversible, because no one would look for it, but would a dealer notice and give you grief for any reason?
Also, adding a few more pictures I've found about this DIY. This way they can be in one place.
Quick Reply: Some photos of air intake resonator chamber
