Solid Mounts
Old Mar 21, 2012 | 09:44 AM
jpm3071's Avatar
Solid Mounts
My motor mounts are bad so I'm planning on doing this. How would I go about taking out all the motor mounts? Can I take all of them out at once? Do I need to do one at a time?
http://grassrootsmotorsports.com/tech-tips/69/
Old Mar 21, 2012 | 10:10 AM
gwiffer's Avatar
Not gonna work...the 3 engine mounts are fluid filled pieces with no gaps. You might be able to add some poly to the 2 or 3 tranny mounts...dunno for sure, though. Your best bet is probably going to be aftermarket mounts.
Old Mar 21, 2012 | 11:42 AM
EL19's Avatar
You can still poly the engine mounts
Old Mar 21, 2012 | 12:50 PM
jpm3071's Avatar
Do you just fill them with poly instead of the fluid?
Old Mar 21, 2012 | 06:47 PM
Excelerate's Avatar
Former Sponsor
We offer an aftermarket motor mount set which is much more durable than the factory mounts. We can also get a 90A bushing if you really want it but the firmest I would recommend is the 75A bushings.
http://store.excelerateperformance.c.../i-300870.aspx
Old Mar 21, 2012 | 08:22 PM
I hate cars's Avatar
You don't want a true solid mount. Your hearing will be shot and you will hate your car. In your case I'm assuming you mean poly filled mounts.
If you go with a poly mount and you have a 6mt, you can benefit from the damper that comes stock on the 5at. I removed mine a long time ago and it does reduce vibrations at idle with the AC on. It might counteract some of the additional vibrations of the poly mounts. If you have a 5at already, disregard.
Old Mar 21, 2012 | 08:56 PM
jpm3071's Avatar
I have a 5at and I took the front dampener off
Old Mar 22, 2012 | 12:24 AM
jpm3071's Avatar
Would the 3M urethane treatment work in this respect?
Old Mar 23, 2012 | 07:28 AM
Inaccurate's Avatar
I can recommend searching in the Second Generation subforum. They have done this a LOT over there.
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
Froid
Sep 27, 2015 06:16 PM
AcuraKidd
Sep 26, 2015 04:10 PM
