Snow Performance water/meth kit
300whp 237wtrq
I installed the Water/Meth Kit by Snow Performance last night and i gotta say it feels like there is a little more torque.
This stuff is awesome. After a bit of spirited driving, I pop the hood and the elbow of the supercharger is cold, and the intake manifold is only slightly warm.
Today is about 75-78 degrees out and the car felt so much more consistant. Usually it feels like it boggs down because of heat soak. but not anymore.
after a bit of spirited driving i floored it from a stand still with VSA off, lost traction in the beginning then chirped a bit at 4000 RPMS and then again at 6500 RPMS. that was all first gear.
Thanks Paul for being a guinea pig on this. great stuff!
Import and Domestic owner
My time from the track tonight
13.71 at 104.29 mph 60' 2.16
My next guinea pig project is NX 35 shot.
Got everything in the mail the other day.
Hoping to achieve a 12.99 at 110mph.
Expect a 13.3 - 13.4 at 108 mph.
300whp 237wtrq
Originally Posted by dtpjigzer
where can i get this snow performance cooler?
300whp 237wtrq
Originally Posted by againstallodds1
Im glad you like it too. Check my mph out on this run. I adjusted the pump a little = smallest jet 175, and 2 - 3 turns down from max on the pump.
how do you know when you are at full pump pressure? doesn't seem like there is a stopping point when i turn with the allen wrench
Originally Posted by ThinJim
what mixture did you use? I've been using straight methanol and like the results.
I heard adding too much octane can cause a loss in power.
Originally Posted by bonesmuggler
How often do you need to refill it?
I use my windshield washer tank which holds about a half gallon. I can usually go a month or two on a tank. about 1000-1500 miles is my consumption. It last a really long time, but my car is not a daily driver. A lot depends on when it comes on and how often. It's a good bang for the buck and doesn't hurt the engine or componets. If you use the windshield tank, be sure not to use straight methanol to clean your windshield, it is a corrosive to paint and body parts. I plug up the line to the spray nozzels for the windshield in case I inadvertly activate it.
Received 1,080 Likes
I heard it makes the windshield wipers go really really fast.
300whp 237wtrq
once i get it tuned i'll start using 50/50 meth/water, which is recommended.
Hondata > *
how are u tuning? via what EMS?
i'm surprised you arent tuning for this. Generally with water injection, you need to advance the ignition a bit since it slows down the initial burn rate -- the keyword is initial. u wont get the full potential of water/meth without tuning done to advance ignition to really harness its benefits.
Realize that methanol can eat away rubber so you should check things like lines that see boost.
'Big Daddy Diggler'
i've been using 30/70 meth/water
Originally Posted by bigman
Dude, get some drag radials up front with the 35 shot you should hit 12's. Your mph are pretty damn good.
Originally Posted by I hate cars
Straight methanol makes more power period. No need for water when talking performance.
I dont think straight methanol will be a good idea, maybe I am wrong but for our car who knows. Without any tuning it wont be that good. You cant advance the timimg on our cars, so using straight methanol might not be good. But I am not 100% sure on this either
1fatcrxnem1
22
06-01-2018 01:23 AM
mrkingstonvi
02-22-2016 01:53 PM
