Side skirt exhaust
#41
P2R (Power Rev Racing), excelerate sells them and he's a vendor here supporting azine these runners will only fit the 3.5 TL motors and not the 3.2 to my knowledge.
#42
Edit* I assume they will only fit the 3.5L due to being made for the Accord EX, correct?
http://store.excelerateperformance.c.../i-222320.aspx
#43
Awesome, thank you.
#44
Mostly the side exhausts would be for uniqueness. So far as I can tell it would be the only one, so definitely unique. I like the flat piping idea. I'll have to look into that.
I have considered the idea of cutouts, but if the side exhausts are too little backpressure, cutouts wouldn't have any performance gain would they? I don't know what kind of backpressure these engines like.
Spray is a non-option. Personal preference, don't want a sprayed car.
The reason I don't want to get the supercharger off the bat is in any engine I'd rather build everything NA then add forced induction. Less things break that way from what I've seen. I feel like a supercharger without doing the other work wouldn't be worth the money. It's also a much larger investment to make at one time, I can build the exhaust slowly, then install it, and then get the intakes, ect. ect.
20whp from precats? holy crap.
I assume power increase isn't your number one priority, or else you'd probably go for a turn down right after the J-Pipe.
A single side exit would be ideal, but one to each side would probably be more aesthetically pleasing. 2.5" in diameter is plenty, as you have to keep in mind that it will still be limited by the 2.25" 3rd cat and J-Pipe diameter. No point in doing 3" unless it's for looks. Remember, a larger exhaust diameter changes the frequencies, usually lower and louder.
As far as routing, I'd suggest oval tubes for the routing underneath, since there is no exhaust pipe cavity to the side, you will lose ground clearance. A giant resonator after the 3rd cat will help a lot. Keep at 2.5" in diameter, or better yet get a chamber muffler (http://www.magnaflow.com/02product/s...e=main&id=8105). Right after that you want to go at either a 45 degree or 90 degree, depending on how much space you have from the center to your side exit location. Fabricate a hanger and attach it to something. Lastly, add some thermal-tape underneath your side skirts so it doesn't melt the paint.
Finally, you have your side exit exhaust.
Besides telling you what everyone else has, that there is a difference between being unique and something that just doesn't look right, it's your car and hopefully this helps you on your mission.
*But for example, this kid is very unique. I have not seen anyone do this before. The unique choice of color, and the way it is applied is dazzling and very eye catching for unprepared bystanders! The problem is not that he's not unique, but just sometimes unique just doesn't look right.
#45
Besides stillhere153, also look up Blackura_NY and his "Beautiful day for a dyno" thread.
Both are NA with just about every bolt on known for the TL. Blackura_NY dyno'd at ~292 WHP (IIRC). Assuming he gained some drive train effeciency, that'd be roughly equal to 330-ish crank HP.
#46
SHAWD 04TL is in
If you really want to do this, than props for you.
WTF... ur a sick mother trucker mike!
BoricuaTL
04-08-2016 01:08 PM
acurajj
02-14-2016 02:28 PM
09-14-2015 10:48 AM
