Rv6 V3 J-pipe flex pipe rattle
Old 03-17-2012, 06:23 PM
  #81
Former Sponsor
Richie v6's Avatar
Originally Posted by dstah
Ugh my rear pcd is cracking again... It cracked completely off but had it welded. It was good for 6 months but I can hear it leak slightly again. I have the v2 pcd..
Shoot me a email or PM and I will take care of it.
Old 03-25-2012, 12:03 PM
  #82
dstah's Avatar
Still waiting on a reply richie. Each and everyday I hear the leak getting louder hope it doesn't crack open soon
Old 03-25-2012, 02:54 PM
  #83
KingKong_Dav
kingkong_dav's Avatar
Yo david, call him over the phone! TEXT HIM or leave a msg.
Old 03-25-2012, 06:19 PM
  #84
Former Sponsor
Richie v6's Avatar
I am working on getting a V2 repaired. No one has ever opted out of my V3 PCD upgrade deal. I should have details monday or tuesday.
Old 03-25-2012, 08:00 PM
  #85
dstah's Avatar
The crack is getting bigger each day. I'm not trying to rush you but I need this asap. I would upgrade to the v3 but I'm short on cash since I've bought a few items for the house. I'm planning to run the repaired v2 for about a month or so then I'll upgrade to the v3.
Old 04-22-2012, 07:46 PM
  #86
rockstar143's Avatar
Received 19,986 Likes on 14,496 Posts
Ok, for Richie, and others since no mention was made of anyone actually doing this, but it was recommended that it might help. Here is my install and review:
I hope it's helpful.
And not sure if anyone ventured over to my FS thread for my jpipe...but thanks, Anil, I took your advice. I started thinking about this whole Jpipe thing and felt like maybe I jumped the gun to sell it. I had thought I'd sell it and maybe buy another brand down the line. BUT GUESS WHAT?!! For all the other brands, even if they're cheaper, it's cause you end up having to buy a race pipe, which RV6 already has included in this jpipe. So I'd lose 100 bucks on what I spent on the pipe to sell it now, act all shortsighted, and when things normalize, I'd have to rebuy a jpipe. Dumb.
So, I had ordered this header wrap for my intake, mistakenly. So it was just sitting, Swoosh recommended I use it. I started reading about the other brand jpipes and it seems, due to the use of the flex pipe, they all end up adding rasp. I will admit that although my car sounded more tame, I did miss the aggressive and low end and the nice gurgle of the exhaust. The way I've been driving, I would never hear rasp anyway.
SOOO...I took my time, was able to loosen the 2 frozen nuts on the primaries (when hot, the nuts came off and the threaded stud stayed in!). Then I put some antiseize on that bish for good measure. I used Richie's nuts (yep, I said it) this time for the front 6 bolts and wrapped both flex pipes with the headerwrap I got on amazon for 15 bucks shipped. I used safety pins and such to pin it into place. I don't know if the rasp I was getting was from resonance...or if when cold, the pipes had more ability to move and when you'd punch it it would cause them to bounce off each other...but, with the header wrap on there, it created a buffer of sorts between then, although very little space, it muffled whatever rasp I had. I took it for a lighthearted spin around the block and it was fine, warmed her up, downshifted to 2k rpms in 2nd and punched it, smooth and MEAN AS FK till top of second, same in third. I'll share this in that Richie rasp thread, to see if it helps.
Anyway, I asked that my FS thread be closed until further notice. I'll revisit if I change my mind again...I left the underneath cover off to make it easier to get to hanger in case I do.
Here it is wrapped, piece of wood to give me some room to wrap:
Here it is installed, used a plastic trim separator to keep spacing while torquing down front nuts.
InFaMouSLink (04-22-2012)
Old 04-22-2012, 08:12 PM
  #87
Chapter Leader (NY/NJ)
InFaMouSLink's Avatar
I've had RV6 V1 Jpipe on since 2009 and never had a problem with it. I'll be soon upgrading to the V3 and will look out for this.
Reason for jpipe upgrade is s/c and new exhaust. Nothing is wrong with the V1 jpipe.
Old 04-22-2012, 09:41 PM
  #88
Very nice, I'm sure you'll have zero problems selling, man. Was the V1 a similar design?!? Maybe I'm just more sensitive to a raspy exhaust!?!?
Old 04-22-2012, 09:56 PM
  #89
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/rv6-j-shift-j-pipe-test-pipe-combo-roll-call-695346/
V1 back in 2008.
Old 04-23-2012, 08:35 AM
  #90
Thanks!
I wonder if the fact that you're starting off with only 1 flex section is reason why there would be less rasp. Drive into work this morning was nice, aggressive and no rasp, as I experienced last night. I guess the only upside to the V3 is the fact that it has the race pipe built in and making the 2 pipes rejoin into one further down the line probably gives better gains.
J.
Old 04-23-2012, 08:54 AM
  #91
equal lengths and a wayyyyyy better merge.
Old 04-23-2012, 08:59 AM
  #92
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
Glad you took my advice bro....and very very glad you keeping the pipe....
the exhaust wrap does work plus with the intake you have the engine should ROARRRR !!!
Old 04-23-2012, 09:04 AM
  #93
^^^I was waiting for you to chime in! Are you punished at home?!? No internet usage?
Infamous, thanks man...guess I didn't realize HOW awesome having the V3 really is.
Old 04-23-2012, 09:08 AM
  #94
swoosh's Avatar
^^^ LOL...
was helping Steven Bell with couple things over the weekend
Old 04-23-2012, 09:09 AM
  #95
Yeah, you painted his brake calipers for him!
Old 04-23-2012, 09:12 AM
  #96
swoosh's Avatar
^^^ no sir....i dont paint !!!
i know what am good at and what am not good at LOL....and painting am not good at....Matt McCollins painted the calipers....i took em off and put em back in, replaced the brakes, bled the system....helped replacing the tails....
Old 04-23-2012, 09:14 AM
  #97
BANNED
SharksBreath's Avatar
Received 2,885 Likes on 1,784 Posts
very cool, J.
is it a good idea to wrap the flex portion tho?
i'm gonna order some of this wrap too and do my precats, and jpipe until the merge at the catback.
did it make everything quieter all around?
Old 04-23-2012, 09:24 AM
  #98
swoosh's Avatar
well equal lengths dont matter as much
what matters the most is the merge....merges and splits is where we loose power.....
very cool, J.
the flex pipe is there for a little twisting around purpose....by wrapping it you only make it a little rigid but it does not mess with its operation....
btw you got text for the exhaust wrap....
SharksBreath (04-23-2012)
Old 04-23-2012, 09:36 AM
  #99
I got my exhaust wrap on amazon...I'll likely follow up by putting a hose clamp on either end of my wrap to keep it from unraveling now that I know it works. I used some T pins to hold in place for now.
I definitely feel like it did help quiet things down and it stopped the raspy sound that was coming from the the flex reverberating at certain RPM's...I believe.
Anil, again, thanks for the idea. My merge is the fkn bomb...
Sharky, please do let us know how wrapping the precats affects the sound/rasp etc...
Old 04-23-2012, 06:48 PM
  #100
under renovations....
CubanLynx84's Avatar
This looks like a good fix. I'd still have to get mine fixed with new flex joints or just get a new jpipe. I rugged mine up being low.
Old 04-23-2012, 08:35 PM
  #101
^^^just scraped, or damaged!?!?
I have an addendum to my repair. As luck would have it, I decided that I should probably use some hose clamps to ensure the wrap wouldn't unravel. I get under the car and what do you know...that bish is already unraveling!
10 pack of 2 3/4" clamps for $9.87 at home depot...used 8 of em, 1 on each end of my wrap and 1 on each transition of the flex pipe, before and after.
Old 04-23-2012, 09:24 PM
  #102
The braided part is kinda opened a bit from scrapping on certain driveways
Old 02-25-2016, 03:54 PM
  #103
yep.
08_UA7_Gr33k
02-11-2016 02:17 PM
ExcelerateRep
10-14-2015 08:20 AM
swany0095
2G TSX Performance Parts & Modifications
10-07-2015 02:18 PM
SiClone
10-01-2015 10:22 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
Quick Reply: Rv6 V3 J-pipe flex pipe rattle
