Rotora big brake rotors
Old Feb 24, 2007 | 02:59 AM
mmcv6's Avatar
313.4WHP& 284.6TQ
Hi. Could you all explain to me the difference of a 1 and 2 piece rotor from rotora big brake upgrade?...I know the 1 piece is cheaper by $425 about besides that what makes the 2 piece rotor better?
thanks
Old Feb 24, 2007 | 01:30 PM
MichaelBenz's Avatar
CTS-V Import Slayer
I think they are generally lighter weight and dissipate (sp?) heat better.
Old Feb 24, 2007 | 06:50 PM
Meek32v6's Avatar
I like to whistle in my
Two-Piece Rotor Upgrade
Advantages:
Lighter rotor (12-16% weight reduction varied with the size and design) than original one-piece rotor – meaning lower spinning weight.
Cooler disc - due to higher heat dissipation rate of aluminum hat than cast iron
True full floating (not all out in the market see design description) allows the disc to expand and contract freely without stressing the hat therefore prevents the disc from warping or cracking.
Replace only the rotor ring, the hat is reusable therefore although the initial cost is higher but the operating cost over the time could be lower than one-piece rotor.
http://www.racingbrake.com/main/two_...or_upgrade.asp
Jul 16, 2017 07:33 AM
Jinkazetsukai
Nov 21, 2015 05:28 PM
lanechanger
Oct 13, 2015 10:56 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
