RL Brake Calipers on 3G TL
Old 06-05-2011, 09:09 PM
  #41
ArthurL's Avatar
Originally Posted by handsom-hustla
on top of the cailpers,
45018-SEP-A60 CALIPER SUB-ASSY., R. FR. -calipers with pins and spring
45019-SEP-A51 CALIPER SUB-ASSY., L. FR. -calipers with pins and spring
45022-SEP-A60 PAD SET, FR.- Brembo OEM pads
51210-SEP-A01 KNUCKLE, R. FR.
51215-SEP-A01 KNUCKLE, L. FR.
57450-SEP-A01 SENSOR ASSY., R. FR. -wheel speed sensor (if req'd)
57455-SEP-A01 SENSOR ASSY., L. FR. -wheel speed sensor (if req'd)
45251-SEP-A51 DISK, FR. BRAKE (17 in.) x2 -rotors,Brembo blanks
45255-SEP-A50 SPLASH GUARD, R. FR. -backing plate
45256-SEP-A50 SPLASH GUARD, L. FR. -backing plate
90651-SEP-A50 CLIP, R. CALIPER x2 -shim between bolt,knuckle and caliper
90656-SEP-A50 CLIP, L. CALIPER x2 -shim between bolt,knuckle and caliper
90107-SEP-A50 BOLT, CALIPER MOUNT x4-caliper to knuckle bolts
01464-SEP-A50 HOSE SET, R. FR. BRAKE- flex hose with brakets and clips
01465-SEP-A50 HOSE SET, L. FR. BRAKE- flex hose with brackets and clips
46335-SEP-A50 PIPE G, R. BRAKE - flex hose to caliper steel line
PIPE G, L. BRAKE - flex hose to caliper steel line
got this from a member here selling his calipers..
https://acurazine.com/forums/car-parts-sale-361/3g-tl-bbk-ss-brake-lines-rotors-810466/
make friends with the search option.!!GL
That's for a Brembo big brake conversion.. are the parts the same for a RL big brake conversion?
Old 06-05-2011, 09:13 PM
  #42
ArthurL's Avatar
Actually I just re-read the OP and you do not need to change out the sensors, knuckles, etc. You just need a custom bracket for the brakes.
Old 06-05-2011, 09:23 PM
  #43
I hate cars's Avatar
Received 1,812 Likes on 1,283 Posts
Originally Posted by brint
I have an 3G 06 tl A.T. What parts to I need to upgrade to the OEM M.T. Brembo set up? Calipers,rotors, and knuckles (all oem) Anything else i need? I'm planning on using green stuff pads.
Do a search, lots of info out there. It's much cheaper to go with an aftermarket BBK than to convert to the Brembos unless you find a wrecked TL and get a great deal on the parts.
Factory Brembos are 12.2". The cheap 12.6" Wilwood BBKs are around $600 if I remember right. I found my 13" Rotora BBK for $800 used.
BBKs are made for the 5at but not the 6mt so there are a minimal amount of parts to swap out. It took barely any longer than a normal brake job to install my 13" kit.
Old 06-05-2011, 09:29 PM
  #44
RIP RBP
upnout's Avatar
For the RL calipers, you'll need 05-06 350Z brembo rotors (12.6-12.8 Diameter) , brackets, calipers, pads. SS lines over the OEM line, will help the brake pedal feel firmer. The BBK upgrade make a big difference in braking!
Old 06-06-2011, 10:24 AM
  #45
soulimports's Avatar
Nice set up
Old 06-16-2011, 01:20 PM
  #46
ArthurL's Avatar
Has anyone used rotors bigger than the 350Z rotors with the RL calipers? I'm interested in seeing the 14" G37/370Z rotors used.
Old 06-20-2011, 08:06 AM
  #47
Comptechtl2367's Avatar
When you get the rotors do you get them for the Brembo set-up or the non Brembo (for the 350z)?
Old 06-21-2011, 02:20 AM
  #48
binhsterbinh's Avatar
Either or. Difference is about 0.2" in size different between 06+ Non Brembo and Brembo version -12.6" vs Brembo 12.8".
jauman (09-27-2013)
Old 10-09-2011, 12:29 PM
  #49
Senior Airman
slowcl-s's Avatar
What he said, I am looking to do the 14" rotors as well. Will these work with the RL calipers?
Old 10-15-2011, 12:14 AM
  #50
pearlUA7's Avatar
Well doneson!!!
Old 10-15-2011, 01:27 PM
  #51
Senior Airman
slowcl-s's Avatar
What specs are your wheels? Thanks
Old 10-16-2011, 08:24 PM
  #52
6th Gear
djkrilla's Avatar
Great Work! The calipers look great.
Old 10-17-2011, 09:32 AM
  #53
Early Shifter
ohsixMTee's Avatar
Nice work.
One question though, those have more braking surface than the MT/TLS Brembos? Pictures can be a little deceiving but it looks like they cover less area.
Old 10-19-2011, 01:21 AM
  #54
ArthurL's Avatar
Has anyone successfully use G37 14" rotors with their RL calipers?
Old 10-19-2011, 10:32 PM
  #55
RL Factory Rotors as well as 06+ 350Z/370Z base rotors are 28mm thick. The Brembo 350Z rotors are 30mm thick which we know fits. The only question is whether the calipers with new pads would be able to grasp 32mm thick rotors found on the 14" FX50 Rotors. Who wants to be the guinea pig? One of us would have to purchase the rotor and test fit it.
Also, I think we would have to have Paul NVA-AV6 fab us a bracket that is 3/4" thicker to handle the rotor diameter increase.
One thing I know for sure is that the 14" rotors WILL NOT clear the factory 17" 5 spoke TL wheels. In fact, it might have trouble clearing some 18" wheels around the the outer edges of the wheel.
BTW, my current wheels are 18x8 with a 45mm offset for the person that asked. Also, the pads have a little more surface area than the TL Brembo pads.
Old 02-11-2012, 02:26 PM
  #56
bukjoe15's Avatar
Question. If my aftermarket rim centric center bore is 64.1 and the 350z is 66.1, would ky rims still fit or would I have to get a converter ring?
Old 02-11-2012, 09:19 PM
  #57
05 SSM
KidChenz89's Avatar
I was wondering which calipers would you guys recommend wilwood or the RL's?
Old 02-15-2012, 07:19 PM
  #58
djagh's Avatar
Anybody have any idea how much of a pain it would be to get either the Brembo or RL front brake setup on a 2003 CL-S 6 Speed? Thanks!
Old 02-15-2012, 08:52 PM
  #59
UA6 SSM TL
24no7's Avatar
how much will the custome alluminium brackets will cost? I tried contact NVA-AV6 but didn't have any luck
Old 02-16-2012, 01:20 AM
  #60
05 SSM
KidChenz89's Avatar
i think theyre either 140 or 160 ...lol im looking for him too my RL caliper will be here in a few days
Old 02-16-2012, 01:07 PM
  #61
cokorote's Avatar
Where do you buy those cheap RL caliper guys?? I went to several local junk yard and I cant find em.
Old 02-16-2012, 01:44 PM
  #62
UA6 SSM TL
24no7's Avatar
is there a way to contact him?
Old 02-16-2012, 06:08 PM
  #63
05 SSM
KidChenz89's Avatar
I have tried to email him directly but no luck
Old 02-16-2012, 08:31 PM
  #64
cokorote's Avatar
Guys where do you buy the RL caliper?
Old 02-16-2012, 10:14 PM
  #65
05 SSM
KidChenz89's Avatar
Went to a few junk yard websites found mine for 95bucks a piece 60k miles on it...i went here http://www.car-part.com/
The following 2 users liked this post by KidChenz89:
cokorote (02-16-2012), jauman (09-27-2013)
Old 03-21-2012, 12:33 PM
  #66
Follow up information post install for bleeding brakes
I've gotten a lot of emails from members asking me if I've noticed a soft or spongy brake pedal post install even after bleeding them. The advice I received from other sources on the forum has been to activate the ABS several times to purge all the possible air out of the ABS controllers. Once this is done, you'll need to re-bleed the front brake lines as the purged air and old fluid from the ABS controller goes back into the regular brake lines. I went ahead and re-bled all 4 lines just to be sure.
When I bled my system after the install, my pedal would still occasionally travel down to the floor, which meant there was still plenty of air in the system. Only after activating the ABS several times and re-bleeding would solve this problem. Member Kidchenz89 had the same issue, and his problem was solved by this method as well.
As for activating the ABS post install - the easiest places to do it would be a wide open street with no one behind you - preferably wet pavement or dirt where it is easy to lock up the tires (although not required). Basically you just go about 35mph or so and lay on the brake pedal as hard as you can and Voila! - Do this a couple times to make sure the ABS has fully cycled and go home and re-bleed your brakes.
Old 03-21-2012, 06:14 PM
  #67
2004 SSM TL
SiriusCity's Avatar
Looks really, really good.
Old 04-25-2012, 01:28 AM
  #68
DoublYouDP
Frankie02's Avatar
i got a pair of those calipers for sale good condition
Old 09-16-2012, 12:40 AM
  #69
Rev High; Drive Happy
o4Komodo's Avatar
Bump.
Just wondering...
Would it be worth any sort of benefit to convert from the Brembos to the RL Calipers?
I found some locally at a scrap yard... wondering if I should pull the trigger on them.
I currently have a 6spd.
Old 09-16-2012, 04:51 PM
  #70
DomGSR-T's Avatar
Originally Posted by o4Komodo
Bump.
Just wondering...
Not really, get some good rotors and pads for front and get a real vented bigger brake kit for the back and you will have a very good gain! I have done it and it's a good modification.
Old 10-04-2012, 01:55 AM
  #71
Acura Noob's Avatar
https://acurazine.com/forums/showthread.php?t=810466
were can i get them used? any one has any for sale.
Old 02-13-2013, 09:37 AM
  #72
Needs a 930
BeezleTL85's Avatar
off to the junk yard sites
Old 02-13-2013, 09:57 AM
  #73
Undying Dreams's Avatar
Received 3,824 Likes on 2,847 Posts
^ exactly
Old 02-13-2013, 10:04 AM
  #74
Needs a 930
BeezleTL85's Avatar
Rock auto has some set ups complete for under 360. Find rotors, SS lines and a mounting bracket and that's all I need?
Old 02-13-2013, 10:10 AM
  #75
WHAT!? Link!!
I think that's all we need.
Arthur L is running Brakemotive rotors, bracket can be made by https://acurazine.com/forums/members/nva-av6-220339/
Old 02-13-2013, 10:24 AM
  #76
Needs a 930
BeezleTL85's Avatar
http://www.rockauto.com/catalog/x,ca...,parttype,1704
Undying Dreams (02-13-2013)
Old 02-14-2013, 03:52 PM
  #77
Okay, I've already got calipers on the way...looking into a rotor now...I see it was mentioned on page 1 that a 13" rotor is possible to do...would the bracket size change at all? Also...what car uses a 13" rotor that has the same bolt pattern the TL does?
Edit: After a little digging, I've found out the 2003 or whatever year you'd like...Mustang Cobra has a bolt pattern that matches the TL's AND has a 12.984" rotor.
I'll be researching a little more to be exact, I don't want any mishaps.
jauman (09-27-2013)
Old 06-20-2013, 08:26 AM
  #78
zachlone's Avatar
Austin did you do this RL conversion yet??
Old 06-20-2013, 08:32 AM
  #79
maharajamd's Avatar
Received 1,544 Likes on 1,197 Posts
Don't believe so. He sold them.
People did the math and realized these actually degrade performance and brake bias.
Old 06-20-2013, 08:57 AM
  #80
zachlone's Avatar
but they look cool
Quick Reply: RL Brake Calipers on 3G TL
