Resonator, and mid muffler delete
What are your views on mid muffler and resonator delete? Im looking for a mean sound even though my TL is just a completely stock 6spd. Will there be any cons to doing this?
Originally Posted by aznbo187
Compilation of all stages of exhaust resonator modification.
So I took the time and made this post so all of the new people don't have to go through 20 pages of discussion.
So far, there are 4 stages of this exhaust mod.
Stage 1.
Least noticeable in exhaust note increase.
Configuration:
Stock exhaust.
Remove mid-muffler. Replace with 2.5" straight pipe. Everything else remains stock.
Cost: Can be anywhere from $30-$60 w/aluminized pipping.
Stage 2.
A tad louder than stage one, a bit more pronounced tone.
Configuration:
Stock exhaust.
Remove stock resonator. Replace with Magnaflow resonator part# 10416.
Magnaflow resonator is a 14" long resonator, which dampens and changes the note of the stock exhaust a bit more, thus you get a bit more loudness/tone.
Cost: Magnaflow resonator costs around $60. Install ranges from $60 -$90 w/ aluminized pipping.
Stage 3.
(Tone result TBA)
Stock exhaust.
Remove stock resonator. Replace with Dynomax resonator part# WLK-24215.
Dynomax resonator is a 12" long resonator, which is a bit shorter and less dampening than the magnaflow resonator, thus it should give you a bit more loudness/tone than stage 2.
Cost: Dynomax resonator costs around $40. Install ranges from $60 - $90 w/aluminized pipping.
Stage 4.
Loudest setup out of all 3. Has a bit of a rasp, similar to M3 exhaust setup.
Stock exhaust.
Remove Mid-muffler. Replace with a 2.5" straight pipe.
Remove stock resonator. Replace with a 2.5" straight pipe.
Cost: Can be anywhere from $40 - $60.
Note: If you live in a climate that is prone to rain, snow, rust, Stainless steel pipping is highly recommended.
This also does not prevent you from passing smog, as it does not alter the characteristics of the catalytic converters, but it does not mean that this is street legal either as it does alter the stock setup of the exhaust.
Media.
Stage 1: Revving
Stage 1: Revving
Stage 2: Revving
Stage 2: Revving Pt.2
Stage 2: Inside Revving
Stage 2: Drive By
Stage 3: Windows Down Driving
Stage 3: Revving
Stage 3: Drive By 1
Stage 3: Drive By 2
Stage 3: 2007 TL-S all-in-one
Stage 4: Revving
Stock Exhaust Configuration.
Stage 1.
Stage2.
Stage3.
Magnaflow Resonator 10416
Dynomax Resonator WLK-24215
Good luck!
aznbo187
Quote:
Originally Posted by Toddy
Hope this helps. I labeled everything in Red for you
Stage 1.
Configuration:
Stock exhaust.
Stage 2.
Configuration:
Stock exhaust.
Stage 3.
(Tone result TBA)
Stock exhaust.
Stage 4.
Stock exhaust.
Media.
Stage 1: Revving
Stage 1: Revving
Stage 2: Revving
Stage 2: Drive By
Stage 3: Revving
Stage 3: Drive By 1
Stage 3: Drive By 2
Stage 4: Revving
Stage 1.
Stage2.
Stage3.
Good luck!
aznbo187
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/removing-resonator-stock-exhaust-summary-post-1-1811-a-589747/
I'm enjoying my stage 4 exhaust for now (mid muffler and resonator delete). until I do the J pipe and PCDs I will be without a resonator but once I do those ill be going with a dynomax resonator
I thought I'd throw in my
I did a Stage 3 (mid-muffler delete; Dynomax res) together with an RV6 V3 J-Pipe. I love the sound at start-up and idle (especially in a garage/parking garage). Under light throttle, it sounds a bit G35-like. Under moderate throttle, there is a bit of what I would call rasp. Under heavy throttle, it simply sounds great (the rasp comes in and then quickly goes away - seems to be centered on a certain RPM range, but I never took the time to check the RPM's when I hear the rasp). During normal driving (city and/or highway) there is no difference in sound inside the car.
One thing I always find ammusing when doing these mods (looks or performance related) is that I am always the one sitting in the car, so I never see or hear the car from outside. About a month ago, my wife was driving the car and I was driving her car. I was standing in the driveway as she pulled away (normal acceleration in a neighborhood). Even in these conditions, I couldn't help but smile - the thing just sounded downright aggressive and looked bad-ass to boot.
Hope this helps.
...I did a Stage 3 (mid-muffler delete; Dynomax res) together with an RV6 V3 J-Pipe. I love the sound at start-up and idle (especially in a garage/parking garage). Under light throttle, it sounds a bit G35-like. Under moderate throttle, there is a bit of what I would call rasp. Under heavy throttle, it simply sounds great (the rasp comes in and then quickly goes away - seems to be centered on a certain RPM range, but I never took the time to check the RPM's when I hear the rasp). During normal driving (city and/or highway) there is no difference in sound inside the car.
Hope this helps.
Hope this helps.
Hope this helps.
Dynomax 24215 Race Bullet Muffler (from Amazon:
DerrickW
Nov 15, 2015 05:52 PM
johnpancakes014
Sep 27, 2015 12:58 PM
