Raspy:(
JDM ... NOT !
Raspy:(
Ok guys, I know I ask alot of questions but I need feedback one more time . So basically I have a XLR8 J PIPE N CATBACK NON RES QUAD and it was set up with a stock 3rd cat and sounded sweet. Recently I put in a rv6 3rd cat delete. Now DONT GET ME WRONG I am not putting down any of the products but after deleting the 3rd cat I get such a nasty, digusting, civic sounding, tin cans vibrating UGLY NOISE from 4100 RPM through 5000 RPM sometimes even all the way until about 6000 RPM. This is my first exhaust so forgive me if this is a stupid question but is that supposed to happen? Is this because the 3rd cat may have no be bolted right or something is wrong. Does anybody else have this same problem. I mean its really bothering me considering I take my RPMS pretty high and a tl s sounding like a 92 hatchback civic makes me want to pull over and slap myself! Somebody please give me some feedback it would be greatly appreciated. Thanks GUYS ! or and GIRLS!
My Garage not
1 Post
did u put in an rv6 test pipe or race pipe? the resonated test pipe shouldn't be as raspy as a race pipe so it sounds like u have the race pipe, although both will be louder than having a cat in there. obviously putting the 3rd cat back in takes away the rasp and a a hi-flow 3rd cat replacement will too, although they are more expensive.
I Have A Meth Lab In
Sounds like the race pipe is your prob, although I am a newb I've read some of the same things with race pipes. A lot of people want that sound and do the race pipes for that reason, even though "race" pipes don't gain much over the test pipes.
JDM ... NOT !
LIST/RAMEN/WING MAHSTA 짱
Rasp with your setup is normal.
I used to have: ATLP J-Pipe > GReddy Evo II.
Now, I have: ATLP J-Pipe > ATLP Race Pipe > GReddy Evo II. Along with this setup, I also got noticeable rasp, but not enough to complain about.
So, OP, it's normal for you to be experiencing rasp. To get rid of it, put your stock 3rd cat back in.
Remember the exhaust flow is only as good as the most restrictive section (diameter).
JDM ... NOT !
So before I get rid of this thread, just to confirm the raspy noise ( civic like loud tin can sounding ugly sketchy unclear and confused vtech noise ) is from the str8 pipe and is normal with a set up like mine ? gosh if somebody with a similiar set up pitched in and told me he or she gets the same noise it would really make me feel so much better
practicing nihilist
practicing nihilist
yes u can.
Like the ATLP or XLR8 cat system it is a simple bolt on.
If u do custom work like a 2 1/2" piping and adding a resonator that would have some welding involved gotta do that at a shop unless u can do it urself lol
Is it safe to say adding a J-pipe to an aftermarket cat back exhaust system will not affect the sound? Please assume factory cats remain in place.
94 DC4 RS LSV/Turbo
I installed the atlp hiflow cat on wanderer's ride, he thought he'd kill the rasp right then and there... it sounded EXACTLY the same... although he does have the precat deletes... which will be slightly more raspier than what you have now
if you want that deep tone you had on your xlr8 catback... simply pickup an aero ar25 resonator... should not run you more than $50 shipped... throw it on after racepipe and voila... it'll make your tone nice and sexy once again...
ps. I don't think this thread was required you could've posted this in the many testpipe racepipe 3rd cat related threads on here
