Questions: 08 TL-S Oem FSB on Basic 04 TL
AZ Community Team
Received 7,770 Likes
FSB or Strut Brace?
The FSB is supposedly a stone cold bitch to get to and replace.
AZ Community Team
meh, doesn't matter. Same part numbers Base and TL-S for the FSB & Strut bar.
OMGWTF4THGENTL
Wrong...
TL-S:
51300-SEP-A21
TL:
51300-SEP-A01
The FSB for the TL-S solid, thus firmer... but you are correct about that stone cold bitch part. You have to drop the subframe to get it out.
I don't think anyones ever tried to replace it before.
Actros tried, and ended up removing the FSB completely... on a FWD car, it's actually the preffered handing setup. STIIF RSB with little to no FSB.
TL-S:
51300-SEP-A21
TL:
51300-SEP-A01
^If your subframe was droppped, would you do it? I assume they put a firmer FSB because the 3.5 weighs more. Would it be beneficial with added weight of the s/c? The only reason I ask is I am replacing my clutch in the near future. I also plan on putting in the motor mounts in at the same time.
^If your subframe was droppped, would you do it? I assume they put a firmer FSB because the 3.5 weighs more. Would it be beneficial with added weight of the s/c? The only reason I ask is I am replacing my clutch in the near future and my subframe and will be dropped in the process. I also plan on putting in the motor mounts in at the same time.
AZ Community Team
Originally Posted by Kennedy
Wrong...
TL-S:
51300-SEP-A21
TL:
51300-SEP-A01
TL-S:
51300-SEP-A21
TL:
51300-SEP-A01
Oops! Missed that. Should've just checked the New Release specs.
Good catch - thanks.
OMGWTF4THGENTL
If you plan to autocross... No.
If you plan for the occassional twisty, but mainly highway, AND have installed the rear Progress, sure.
R.I.P my WDP TL
Yea it is hard to remove and replace, what about the Sway bar right under the hood and rear sway bar. I see alot of people get the Progress auto rsb.
IBankMouse
06-13-2020 12:53 PM
