Question about exhaust welding
Didn't get a chance to ask the shop this question so here it goes...What size tubing do I need for the outlet coming to the red arrow 2.25' Inlet muffler.
What size inlet tips do I need for the blue arrow 2'' outlet.
This is what I was thinking so correct me if I'm wrong...
Outlet tubing (2.5'')----->(2.25") Inlet muffler
Outlet muffler(2")------->(2.25") Inlet tip
are you buying everything? It really depends on the shop. When I built my exhaust, I bought everything to match the inlets and outlets. All the tips I purchased slipped over the muffler ends and if they didn't, I used a pipe stretcher to make it fit.
The same goes for the inlets. I buy the same size and expand the pipes to fit over. If the shop has a really good welder, then they can butt weld without expanding.
One on the right for me
Hey man is this set up for a TL or TL-S? I have a 07 TL-S and I know the stock cans are pretty short. Wondering if this would fit my car.
Another option is grinding. If you are planning to paint the exhaust after welding, then use a grinder to smooth out the peaks and valleys of the weld bead. Granted, be careful to not remove too much of the bead to make the weld prone to crack.
In my old hotrod days with my Camaro, this is what I did.
I did that too. If I needed something to look really nice I'd just use the TIG welder but that took a lot more time. Smoothing out with a grinder is a good alternative.
IIDXholic
10-08-2015 07:53 AM
Billu99tl
09-13-2015 11:30 AM
Hau_nguyen91
09-06-2015 12:53 PM
