Which pulley is better for the SC?
J30 360whp/310wtq @ 7PSI
which pulley should i get that will gives more power with Supercharger?
UR under drive pulley or UR stock pulley or OEM pulley?
347hp/300tq @ 4psi
why peter? did you get the SC installed yet?
the UR underdrive pulley will lower the boost, so if you want a lightweight one go with the UR pulley that is stock size. i say dont even bother with a lightweight pulley, just stick with the oem. it has a damper in it, to fight off crank vibration. the few hp you get from it, is not worth the longevity of your motor.
BTW, i still have my basemap for the 3.0, so if you want to download it, you can. im going to churches to get my car tuned this coming monday.
not yet...
cuz the motor is delay till October...
so i cant install it until the motor come =[
finally going to dyno it?
i wanna see how fast can it go!!!
ill say 310! or 320!! harhar
Former Sponsor
To the OP you would want the stock size pulley, the Ultra Sc.
Originally Posted by Excelerate
The OE pully has a rubber ring or elastomer to reduce Noise Vibration Harshness, which basically means to make it so there isn't any noise in the cabin. UR has been in business for decades and there are sundry CL/TL's on this sites with tens of thousands of miles with no adverse effects. In fact there was one guy on here with over 100k w/ the pulley w/ no problems.
mrkingstonvi
02-22-2016 01:53 PM
