Preliminary Supercharger reflash results - looking for a tester
#125
tehLEGOman
Received 1,982 Likes
Start driving west across nevada and head to Hondata!
#127
tehLEGOman
::lurking in this thread::
::looks at the printout from my dynojet, then looks at hondata results and cries::
#128
#130
Oderint dum metuant.
He posted his numbers in another thread (don't remember which one)...let's just say my almost stock car could probably keep up with his
. The poor guy needs a tune like I need to win the lottery.
Eric, take a couple days off of work and send all of the required parts to Hondata...it'll be worth it...you're leaving too much on the table as is.
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
#131
Originally Posted by hondata
Our development is driven in large by two things.
- 1) Bang for the buck
- 2) Requests by our partners (ie Comptech)
I have been working with the supercharger system for over 18 months and have been developing the software to a point where it makes a big difference to someone who has a supercharger with the ACM. The TL runs like it was supercharged from the factory.
The reasons I am asking for testers, is that in the small samples of TLs I have had, there have been performance variations in otherwise identical setups. This goes for the NA TLs I have tested as well. In addition the TL performs significantly differently on the dyno than it does on the road. This alone has added months to the development. We appreciate those who have been and are still working with us.
The release of this product has involved a tremendous amount of work. There are not one, but 6 reflashes, one for each year 2004, 2005 & 2006, MT and Auto. It is unlikely we will recover even 1/4 of our costs with the supercharger reflash, but we invested this time as we believe there is a lot of future potential.
Once the framework is in place for reflashing the TL ECUs for the supercharger it becomes easier to develop other products for the TL. For example our technology could be applied to a turbo system.
Later this year / early next we will look more closely at the NA TL. What we have found so far is:
- Dropping the VTEC point is detrimental unless you have low restriction catalytic converters and a low restriction exhaust.
- RL cams can be fitted and tuned for, but the VTEC point needs to be raised
- The NA reflash in the two TLs we have worked with, perform better on the road than on the dyno.
There are many possibilities, but we cannot do every combination.
To answer other questions:
If a customer with one our reflashes upgrades of another of our reflashes there is a lower charge. For example 600 for the first reflash and 300 for the next. In this case the reflash upgrade only applies to the ECU. Ie if the car is sold with a reflash, the new owner may upgrade. We keep a record of the serial numbers.
#132
312 HP 271 TQ Dynapack
I finally crawled out from under my rock...
How did I miss this thread for this long??? I got the reflash done a few months ago, but my gains look nothing like that!!! Then again, Ussi's modded up the yinyang with that dyno pull.
I pulled 294 hp and 260 TQ w/ 5AT s/c & procats
Ussi pulled 327 HP and 280 TQ w/ 6MT, procats/third delete, j-pipe, s cams, port n polish, comptech/HKS exhaust & more?? Did I miss anything Ussi?
But Hondata, If you say a stock TL pulls a 240 HP on the dynapack, wouldn't a 54 HP gain for s/c & procats be a bit small? I think my reflash need updating, but I would rather wait for HBP reflash.
I've been calling Autowave every couple of weeks asking for updates & offering my car for testing. But so far; no significant updates and no need for my car.
It would be nice to be in direct communication w/ Doug/Hondata.
Let me know if u need a tester! I'm close by and willing.
'06 5AT TL
Thanks for all your support!!
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
![Racing](https://acurazine.com/forums/images/smilies/racing.gif)
#133
ill ask doug if he needs you when I talk to him. If you plan to put the hbp on you will need to put on the stock rsx type s injectors so you dont go lean. Do you have the money for the rsx type s injectors ? ... if so hondata might need you.
let us know...
let us know...
#134
let us know...
let us know...
#135
I got you hooked up with doug directly. So as long as you have about 700 to 1000 for the injectors and labor unless you put it in yourself. pm me for my cell and I will inform you more.
cool
cool
#137
tehLEGOman
Action, Action, and more Action!! good work guys keep up the spirit!
#138
347hp/300tq @ 4psi
![Scratch](https://acurazine.com/forums/images/smilies/scratch.gif)
i dont get it. one member on v 6 p just recently dyno'd his v6 accord (3.0 5AT) 293hp at churches. besides having RDX injectors (410cc) and exhaust, everything else is pretty much stock. he tuned just the a/f only, since we havent figured out how to open the ignition maps yet.
i dyno'd at 328hp/280tq at churches, with the same #'s as ussi. i have procats, RSX injectors, comptech exhaust, but still have the stock pulley, stock jpipe, no cams and third cat, i too am using the greddy ultimate with only the a/f tuned. something is just not right here ??
i also got my car tuned with the greddy blue on the same day. though i was able to open the timing map with it, i made 329hp @ 6000rpm
![EEK!](https://acurazine.com/forums/images/smilies/eek.gif)
oh BTW, doesnt hondata drop the vtec down to 3000 rpms also??
#139
I (don't) whine.
my #'s were closer to 350hp/288 peak on the stock pulley also.
#140
347hp/300tq @ 4psi
Originally Posted by ussi
293 on a stock motor?? um..how?
ohh, and 350hp/288 sounds more like it.... then who's dyno chart did hondata post?? i heard something was wrong with you car too? what happened? makes me start to wonder how stout these motors our under boost.
#141
#142
Team Anthracite
whats the point of changing the fuel injectors if you cant really tune the fuel man????
btw... what is the stock TL injector size?
i am so looking forward to having my car flashed with Hondata.... too lazy to piggyback...
#143
300whp 237wtrq
Just wanted to come out and thank Hondata for taking the time to work on our cars.
Even though it seems like it's taken forever to even get to this point, I'm comforted to know that Hondata is pouring a good amount energy into R&D. And even just with that, a lot of companies just don't do that anymore. anyway, THANKS!
#153
tehLEGOman
Do work.
#157
tehLEGOman
Originally Posted by bent09
![Sad](https://acurazine.com/forums/images/smilies/sad.gif)
