Precat delete cause a code?
Old Oct 5, 2021 | 09:59 AM
jfman55's Avatar
I'm swapping my engine on 05 TL 6 speed. Just took cats off n they are shot. I got an aftermarket exhaust that came with precat deletes that I wasn't going to use because I thought it would throw a code. Would they throw a code?
Old Oct 5, 2021 | 11:24 AM
if the Precat deletes did not come with defoulers, then yes. it will throw a code.
a defouler is sort of a spacer.
it spaces the 02 sensor from the exhaust stream, if spaced correctly, the 02 sensor will act normally and not throw a code.
if not spaced correctly and 02 sensor sits in un-filtered exhaust stream, car will throw a code
Old Oct 6, 2021 | 06:58 AM
jfman55's Avatar
Thank you! I bought the last tsudo high flow cats I could find. I already dumped so much money into this car that I wasn't springing for the rv6 ones.
KidChenz89
Feb 10, 2012 01:17 AM
AcuraCar99
Oct 26, 2009 08:42 PM
bkzjimmy
Dec 26, 2005 02:06 PM
